TPI differences 85-92
Old Dec 27, 2005 | 10:31 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default TPI differences 85-92
Anyone have this article handy? I'm trying to identify an F-body TPI setup, dunno what year it is from 85-88 (or if it matters)
Also trying to figure out if a MAF tpi can be easily converted to MAP/speed density. I've never even seen a map sensor or plenum.
Old Dec 27, 2005 | 10:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont know particulars but the 89's have no 9th injector and the Camaro runners have a smooth finish on the outside as opposed to the rough cast on the vettes.
Old Dec 27, 2005 | 10:44 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Hey CC,the F cars and the Vette were the same with the cold start injector until 89 when they did away with that.I do believe the F cars intake manifold bolt pattern changed in the middle bolts,but not sure what year they did that.Thats why the aftermarket TPI manifold bases have a weird looking central bolt hole,elognated if thats the word,to allow both style intake-head bolting set up for either car.
The map sensor would be on the outside of the plenum.The vacuum hose routing was a bit different but not much from the MAF set up.
I remember a 91 MAP system on the vette,the MAP sensor was right at the back of the plenum where the 2 vacuum ports are at.Passenger side that is.
Also,if it helps, www.thirdgen.org has alot of info there as well.
It seems theres more knowledgeable TPI people there than here.
Old Dec 27, 2005 | 11:14 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by CentralCoaster
Anyone have this article handy? I'm trying to identify an F-body TPI setup, dunno what year it is from 85-88 (or if it matters)Also trying to figure out if a MAF tpi can be easily converted to MAP/speed density. I've never even seen a map sensor or plenum.
Try this link
Old Dec 27, 2005 | 11:23 PM
bmalec's Avatar
bmalec
Nice link, JrRifleCoach!
Ben
Old Dec 28, 2005 | 12:34 AM
86PACER's Avatar
86PACER
Originally Posted by JrRifleCoach
Nice.
Old Dec 28, 2005 | 01:59 AM
CentralCoaster
Thanks. That page is getting bookmarked. Now can you do me a favor and come down and do some wrenching?
To TPI differences 85-92
