Replacing CCM how to program?
Old Jan 1, 2006 | 05:14 PM
corvette1989bham's Avatar
corvette1989bham
Default Replacing CCM how to program?
I am replacing a CCM in a members 95 Corvette die to a intermittant no crank condition (diagnostics complete its the CCM). The factory service manual says if CCM replacement is need call the techincal hotline??? I know it has to be programmed, can someone give step by step directions via a tech1a or Tech2.
Old Jan 3, 2006 | 02:21 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Old Jan 3, 2006 | 04:01 PM
corvette1989bham
Old Jan 3, 2006 | 10:35 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
The CCm is located behind the radio/AC unit. The VATs key will program automatically when you insert the key and turn the ingnition on. Make sure you clean the key before you install it. The mileage has to be set with a Tech1A. You have only 16 miles you can drive before the mileage is no longer programmable.
Old Jan 3, 2006 | 10:46 PM
corvette1989bham
Thanks, I did know that part, its the downloading the data from the old CCM I am unsure about. I have a Mass storage cartridge on my Tech1. Do I just go into programming menu and get info. I want to ask how before I just try is that if I make a mistake, I cant undo it, I guess that is my main question. If the upload fails then BOTH new and old ccm are no good right? The data is erased from the old CCM after upload (or download to tech1a is another way to put it) so you only get on shot at getting it right?
Old Jan 3, 2006 | 10:50 PM
Zip Corvettes
Yes you only get one shot. However some of the speedo shops are figuring the CCms out where they are rebuilding them which means anything is fixable. I believe it is in the programming on the Tech1a.
Old Jan 4, 2006 | 10:59 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
what is a tech 1a?
Special GM computer?
Old Jan 4, 2006 | 11:14 AM
kalister1's Avatar
kalister1
Tech1A is a two way code reader used by chevy dealer, called out in the FSM. Sometimes you see them on E-BAy with different cartridges for around $400.00
Old Jan 4, 2006 | 04:57 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Old Jan 17, 2006 | 11:00 PM
corvette1989bham
Still looking for answer on the reprogram and upload.
Old Jan 18, 2006 | 02:06 PM
WEH 2000C5's Avatar
WEH 2000C5
If a ccm is not programmed in 16mi will the only outcome be no miles or start over@ zero . By speedometer are we speaking only of the Odometer? Please explaIN the ramifications of not having a dealer program it & continue to drive it.
Thank You.
Old Jan 18, 2006 | 08:27 PM
corvette1989bham
If it isnt programmed you run the risk of vats pellet becoming somthing different. ALso, it will show that the CCM isnt original with the car if you dont program it. I just want to know if when you download the OLD ccm data does that (old)CCM become ruined. I want to be able to mess one up if I do something wrong and know it can be fixed.
Old Jan 18, 2006 | 08:45 PM
JackDidley's Avatar
JackDidley
Send a PM or email to tjwong, he will know.
Old Dec 5, 2020 | 10:42 AM
corvette.zr1's Avatar
corvette.zr1
Cruising
CCM Programing 1990 - 1992
http://www.corvette-c4.eu/corvette_c4_ccm.pdf
Gruß
Raimund
To Replacing CCM how to program?
