Mini ram or super ram
Old Jan 4, 2006 | 11:34 PM
  #41
hookedup's Avatar
hookedup
Hey Jeff!
Beach,
Nice comparo analysis, you are right on with those suggestions.
Catch ya' later,
Dave
Old Jan 4, 2006 | 11:54 PM
  #42
Beach Bum's Avatar
Beach Bum
Originally Posted by hookedup
Beach,
Catch ya' later,
Dave
Thanks Dave !! And my recommendation for you... I think your motor would run better with stock, but ported tube runners and a big mouth.
How's Phil C. doing ? Is he in the 8's yet ? Last time I talked to him he was knocking at the door....
later
Beach
Old Jan 5, 2006 | 12:18 AM
  #43
hookedup's Avatar
hookedup
WOW, stock runners, why didn't I ever think of that
Both our cars went under the knife lately, mainly safety upgrades, etc.
I'll likely pull my engine for a freshenup when it gets back from the chassis shop.
Phil sat out most of last year and still has to get his engine back together.
Haven't heard much from you lately, figured you'd be getting some track time in since moving. Whats the matter, is your job interfering with your racing habit?
Good to hear something out of you again,
Dave
Old Jan 5, 2006 | 03:26 AM
  #44
hippy's Avatar
hippy
There was that other mag article where they swapped the SR with a converted LT1 intake and the SR was around .4 mph and a couple tenths. For those kinda numbers I sure wouldn't subject myself to the agony of another multi piece intake install.
Old Jan 5, 2006 | 03:38 AM
  #45
cv67's Avatar
cv67
St. Jude Donor '05
I'd gladly give up a few ft/lbs if I never had to fool with a TPI again.
Old Jan 5, 2006 | 07:00 AM
  #46
Beach Bum's Avatar
Beach Bum
Thats one thing I have never understood.... people will sacrafice power because the performance part takes longer to put on.....
Look at it this way, lets say you take off your intake once a year. (Most don't)..... and it takes 2 hours longer than the other intake system, but you say the heck with that... I'll go with the easy to install intake, even though it makes 48 ftlbs less torque...... so basically what you're doing, is sacraficing 48 ftlbs of torque 364 days of the year, so that on "one" day you didn't have to spend 2 extra hours putting on the right part in the first place..... mystifies me... but to each their own.
Old Jan 5, 2006 | 07:40 AM
  #47
85vet's Avatar
85vet
Cruise-In V Veteran
Beach,
I am going to post your quote for the day up in my garage and every time I get frustrated I will read it to clarify my mind as to WHY I am doing it in the first place.
PS. We(Cork & I) have a few minor adjustments in process to try to hit that 10.9999999 elusive ET.
Old Jan 5, 2006 | 08:06 AM
  #48
mseven's Avatar
mseven
Well since it's getting beat in the ground (MR vs SR), here is my take.
My reasoning was not just ease (good one, not only one) but by the time the set-up is making some real power I would have to get into the trans. and rear end. I also considered future reasonable goals bigger inches, I felt without having track only car/set-up a MR could meet that goal.
I am not for the record disputing torque here and am looking at the entire picture. I am only saying that at a point if you hitting the trans /rear end with say 400+tq. other issues will arise, so if I have to get in there anyways there is no difference, to me at least. (Thoughts here are the d36 can/will break if you are hooked, so either way a 44 would be in order. Just the stock components in a 700r cast rings, shell, etc. aren't going to last long, a conv. is ness. either way.)
The only thing I would think becomes speculative is the size of conv. and cam that others have stated becomes nessessary, to me that would depend on how fast do you want to go to begin with. (a side note the 1.4 range 60's mentioned earlier is great, I would think any set-up regardless, is going to need some work to achieve those numbers, please correct me if I am wrong here).
As many have said, it is about the entire set-up, and I definetly agree with that statement, and believe there are just alot of ways to get there. By the way I also think at a point (again set-up realated ) the single plane is a nice set-up, and at that level probably the better option. As one member had stated, that for 90% of the forum members the sr overall would be better suited, and meant as just a motor upgrade only, that would satisfy there desire at better performance without other upgrades, that might be all most are willing to do.....I guess it all depends, as I see several here who have very fast cars and it didn't stop there. another .02
Old Jan 5, 2006 | 08:34 AM
  #49
ralph's Avatar
ralph
Beach, at first i had to reset the lash like every week. It appeared that the polylocks on the rockers were taking shape... But once it settled down, the lash rarely moves and i have't checked it since around June.......so i'm due. I will say my valve train is very noisy, especially before it reaches temperature. Sounds like a can of screws Maybe it's just because my exhaust is too quiet...LOL.
ta, that's a good running combo. You probably have me by about 1-2 tenths and 3-4 mph. At 1700ft, i'm usually in the 30s with full exhaust. Assuming 2-3 for the exhaust, i'd be 11.ohs @ 123/4. You're short timing a full tenth quicker than me. I've got a tight converter, and as Beach said, it would surely be quicker with a looser converter, but i dont want to put more pressure on the rear. Did you say you were running a lock up??? What is your ICL on the cam??? I've got mine advanced 8 deg since i set it up for the superram. Was thinking of setting it straight up, but i'm afraid i'll hurt my short times with this tight converter. Have you had your heads flowed??? Those comp ported 195s are working well. I couldn't deal with AFRs 4 month lead time, so i went with the track 1s. They out flow the AFRs, but are a little larger. Are you still using the stock ECM? Who did your tuning???
Old Jan 5, 2006 | 01:01 PM
  #50
hippy's Avatar
hippy
While that is true what I said is one reason I can look back now and say I am glad I went the route I did. The main reason I am not running a SR is because of availability this summer of the SR, you couldn't find one.
Plus those numbers I listed are so close from each other I know for a fact I am not that dedicated of a race car driver to achieve repeatability close to that. And for me it would only get worse with more low end tq on the low end. So, if I can have a car that close for a lot less aggravation I will definitely take the less aggravating setup.
The Mini gets a bad rap as far as losing so much TQ, I lost 4 lb ft on the dyno when compared to my LTR bigmouth/bigtube setup. I don't think that is substantial.
Once I get my rear end gears taken care of I am shooting for Bjankski's 114 he got out of his SR car, or close to it.
Old Jan 5, 2006 | 02:30 PM
  #51
JAKE's Avatar
JAKE
Originally Posted by bowtie350_428
I know I am opening a can of worms with this one but...
Does anyone know why Grumpyvette's Smaller HSR plenum design fell out of favor?
Did the smaller HSR plenum hurt performance? Is there Proof?
And finally, does anyone know who makes a modded plenum that allows the HSR fit under our C4 hoods?
There was a site that offered a HSR that fits under the Vette hood without any mods, but the last time I tried to access it (well over 6 months ago) it wasn't up. They also offered the fuel rails, etc., for the swap. Photos were nice too.
There was not data listed as to how the airflow was effected by modding the HSR to fit.
Unfortunately I believe I lost the link, but I'll look further on my hard drive. If I come up with it I'll post or prehaps someone else has it and will do the same.
Jake
Old Jan 5, 2006 | 02:48 PM
  #52
JAKE's Avatar
JAKE
I found the link: it WAS:
www.fasterdeals.com
but when I just checked it was still NOT UP.
Jake
Old Jan 5, 2006 | 03:21 PM
  #53
87_ta's Avatar
87_ta
Hi ralph,
Thanks! Yes my converter has a lock clutch, and it 12" but is currently not working... Its a 10" converter with a ridge welded around it for the larger 12" clutch.. ads about 12 lbs over a non lock
the cam is advanced 4 degrees, and as mentioned earlier I do my own tuning..
I agree with the AFR 4 month lead! it sux..
We should swap heads, it will help your 60ft
Old Jan 7, 2006 | 10:36 AM
  #54
Beach Bum's Avatar
Beach Bum
Dave
Hi Dave,
My job has me running across the country most weeks.... and my wife monopolizes any remaining time left.... very little time for fun stuff nowadays including surfing the forum like I used too.... oh well, whadda ya gonna do.
I know how Phil C must feel, I sat out most of last year too.... tore it apart, and just haven't had two minutes to finish anything since... oh well, maybe this year.
later
Beach
Old Jan 7, 2006 | 10:37 AM
  #55
Beach Bum's Avatar
Beach Bum
Thanks for the information Ralph !!
Old Jan 7, 2006 | 08:36 PM
  #56
86 plum crazy vette's Avatar
86 plum crazy vette
Beach,
I love my Mini-Ram !
Still the same engine just a different cam & manifold
Dave
We use a Mini Ram on our 86 Corvette, and it works great!
434 SB, TPIS Mini Ram, Brodix Track 1X's, Bowtie Block, 680 solid roller 114 center line, 4" Callais crank, Gen 7+ (DFI), 55 lbs injectors, NOS Fogger (250-300), tight 4500 nitrous convertor, 400 turbo trans, stock style IRS, 3.73 gears, Weld wheels, 325 M/T Drag radials, and 3.5" exhaust. The car weighs 3450 lbs and the best ET NA is 10.48 @ 132 mph, and the best NOS is 9.107 @ 151.73 mph with a 1.35 60' P.S: Dave that car of yours leaves nice! You can see pics of our car at www.racesupercars.com Steve
Old Jan 7, 2006 | 08:43 PM
  #57
86 plum crazy vette
Very good point!
To Mini ram or super ram
Old Jan 14, 2006 | 12:36 AM
  #58
bowtie350_428's Avatar
bowtie350_428
www.fasterdeals.com
Jake
In my search for an HSR modified plenum that fits under the C4 hood, I've come across that link before. Its been saying it "coming soon" for a long time. But just how soon is soon?
I wonder if they just realized their design is flawed or they just have no funds to go into production. Guess we'll just have to wait.
But hey... thanks anyway Jake.
Old Jan 14, 2006 | 07:10 AM
  #59
yedister's Avatar
yedister
Originally Posted by importkiller92
I am looking to build a supercharged 391, and I can't decide which to use. I have read some people having issues with using a mini ram on a forced induction set up and I am looking for some input from someone with first hand experience. Also does anyone know the intake port size of the mini ram?
Check out these links:
http://www.vetteexplorer.com/cgi-bin/mv.pl
http://www.thirdgen.org/techbb2/show...oto=nextoldest
http://www.geocities.com/MotorCity/7610/drivetr.htm
Hope this helps
Old Jan 14, 2006 | 07:30 AM
  #60
88BlackZ-51's Avatar
88BlackZ-51
there are many things to consider when comparing these intake, and one is rear gear ratio. for instance guys with 3.07's, and dont want to change there gears then the SR is the right intake, etc....
many variables, i didnt buy it because i heard that its a pain in the *** to install, and the MR is cleaner looking and more refined.
