Could this start a fire?
Old Jan 6, 2006 | 11:03 AM
batoutofhell's Avatar
batoutofhell
Default Could this start a fire?
When i bought my 85 the previous owner had installed a switch to turn on the fan. My fan stopped working and I noticed the switch was loose and then I noticed that the wire was hot (i burned my finger). So I replaced the switch with a 50 watt switch (the wire is thick). I use to have a camaro and I did the same thing but I spliced used the grounding technique. This previous owner for whatever reason directly has one wire to the battery and the other to the fan. Is this safe or can it cause a fire. I replaced the switch about six months ago but I never noticed the wire was hot until now. Thanks.
Old Jan 6, 2006 | 11:50 AM
kalister1's Avatar
kalister1
You should have a fuse between the battery and the fan at least.
Old Jan 6, 2006 | 11:55 AM
batoutofhell
If it melted a 50 watt switch, what amp of fuse do you think I should use and again is this normal for the wire to be that hot, I never touched a wire that was hot before. Thanks.
Old Jan 6, 2006 | 12:23 PM
ripped_78's Avatar
ripped_78
Always hook a relay up to something like that, it's cheap and it gives a little peace of mind.
Old Jan 6, 2006 | 01:04 PM
batoutofhell
But is it normal for the wire to get hot?
Old Jan 6, 2006 | 01:09 PM
kalister1's Avatar
kalister1
NO If the wire is hot to the touch it is too small for the current load. That's where ripped 78 says to use a relay. You let the relay carry the high current and the switch only turns the relay on and off. Look in your fuse box on the car, I don't think they even make a 50 amp fuse. If your fan is pulling that much current there is something wrong with it!
Old Jan 6, 2006 | 01:16 PM
batoutofhell
The wire thats on there is pretty thick its the kind that barely bends. What kind of relay should I get. And also, what would cause the wire to get that hot? I just replaced the fan not to long ago. Thanks for all the replies. Where would I put the relay inbetween the battery and the switch.
Old Jan 6, 2006 | 01:29 PM
CFI-EFI's Avatar
CFI-EFI
That sounds like a solid wire, like used in building wiring. Not stranded wiring as used in automotive applications. That fan was probably set up by a carpenter. Or a bookkeeper. Or someone that knows little to nothing about cars and/or electricity.
I would use the one that came on the car.
Too much current flowing through too small of a wire.
RACE ON!!!
kalister1's Avatar
kalister1
I don't know, maybe radio shack, or try auto parts store? The relay would get wired to the fan with power and ground. The the switch would wire to the relay. When you turn the switch on the relay contacts close and turn on the fan. So the switch only activates the relay, not the load that is on the relay. The relay should have a wiring diagram on it or with it when you buy it. Bad or loose connections will cause heat, that is how curcuit breakers work. Check all wires, connections and grounds for loose or bad connections. Try to keep all wires as short as poosible, the longer the wire the less current it can carry. But it seems to me that if the wire itself is getting hot the fan is pulling too much current. Can you find out from the fan's manufacturer how much current it is supposed to draw? That will tell you how big the relay and the wires need to be.
Old Jan 6, 2006 | 01:41 PM
batoutofhell
wow the previous owner really mickey moused this one, I guess he totally bypassed the fan relay since its running directly from the battery. Where is the fan relay located on the 85? I think i'll buy another one and hook it up the proper way.
Old Jan 6, 2006 | 01:54 PM
CFI-EFI's Avatar
CFI-EFI
It should show in your factory service manual as will the wiring. On my 1984 it is on the rear of the left inner fender panel, just below the master cylinder. Your old one may still be there.
RACE ON!!!
Old Jan 6, 2006 | 02:33 PM
batoutofhell
Thanks for all the help. God I love this site.
Old Jan 6, 2006 | 02:40 PM
1990 c4's Avatar
1990 c4
Cruise-In VII Veteran
Run a wire from ground through the switch and splice it into the negative control wire going to the existing relay. There are two small wires connected to the relay. The one you want is the one that is grounded (check with ohm meter). The ground wire can be small, 18 gauge is fine.
Old Jan 7, 2006 | 12:20 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes, the switch should be on the ground side of the relay. Anything else is a fire hazard, and actually more work.
Old Jan 7, 2006 | 12:43 AM
jfb's Avatar
jfb
Switches are not rated in watts, they are rated for current and voltage capacity. Your fan draws 14 amps when running and it is powered by a relay that is fused. If you want to manually switch your fan on, wire your switch to ground the fan relay coil that is grounded by the ECM. On my 87 vette, this wire is green/white and the relay coil wire that has 12v when the ignition sw is in RUN position is dark blue. Your 85 probably has the same wire colors. 14 amps through a too small wire and switch will make them hot! Relay coils draw very little current and small size wire and a small switch can be safely used to operate the coil of a relay.
Old Jan 7, 2006 | 12:47 AM
CentralCoaster
Yeah, it's green/white.
Old Jan 7, 2006 | 12:50 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
W=V x I
To find out what fuse is needed find out the amperage of the motor.I would guess it is more than 5 amps which is what a 60W switch would handle at 12V.The wire guage is important too 14g can handle 15 amps 12gcan take 20.I bet the wire is the wrong size.
http://www.powerstream.com/Wire_Size.htm
To Could this start a fire?
