No codes
Old Jan 6, 2006 | 11:10 PM
Dave-B's Avatar
Dave-B
Default No codes
Last week my 86 4+3 started running bad, and my service engine soon light came on. I put it away in the garage and that night I started it up again. Run fine, and no service engine soon light. I used the paper clip to A-B two different times and both times all I got was SERVICE ENGINE SOON. As far as I know, I did it right!!!! Put the clip in A+B ---turned the key to on----and waited each time for a few minutes. Why not any codes. Is somthing wrong with my ECM or what???
Old Jan 7, 2006 | 12:04 AM
Morley's Avatar
Morley
If the light works and you can't even get code 12, then, yes it may very well be the ECM.
Old Jan 7, 2006 | 12:11 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
So... you jumpered A to B
OOOOAB
OOOOOO
And then turned the key on. And the light didn't flash morse code at you? The electric fan didn't come on, or the overdrive light come on?
Sounds like your jumper wire isn't making contact.
Old Jan 7, 2006 | 12:19 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Same thing on my 93.I get the codes if I jumper A&G on the digital display.No flashing SES though.And my relays turn on.
Old Jan 7, 2006 | 01:24 AM
Dave-B's Avatar
Dave-B
Default No code
SORRY----My fan----OD light----and door ajar is on, plus the SERVICE ENGING SOON LIGHT blinks on and off. That is all that happens. I just went out and checked it again??? So it sounds like my ECM?? What now?? How do you tell if the lights are working? Dave
Old Jan 7, 2006 | 01:27 AM
CentralCoaster
That's what it's supposed to do.
Watch the flashes.
flash flash pause flash is code 21.
It'll do that three times then flash each trouble code three times.
flash flash flash pause flash flash is code 32, and so on.
When it flashes 21 again, it's done. The codes will repeat after that. Also, code 21 is not a trouble code.
Old Jan 7, 2006 | 01:53 AM
Dave-B's Avatar
Dave-B
Now I get it!!!! I was looking for numbers, not the amount of flashes!!!! I had code 12---34, and 42. I know the last two is what I'm looking for. I'll get the book out tomorrow and see whats up. Thanks for setting me stright on this. Dave
Old Jan 7, 2006 | 02:00 AM
Morley's Avatar
Morley
Watch the flashes.
Not to nit pick but...code 12 is the one he is looking for to begin and end the sequence......we'll get him all looking for 21.
Old Jan 7, 2006 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Heres some good reading for you
http://members.shaw.ca/corvette86/No...it%20Check.pdf
http://members.shaw.ca/corvette86/Code%2034.pdf
http://members.shaw.ca/corvette86/Code%2042.pdf
Old Jan 7, 2006 | 02:26 PM
CentralCoaster
I wouldn't know because my car never breaks down.
Old Jan 7, 2006 | 05:55 PM
Redeasysport
Mine never flashed for some reason.Still waiting for some one else that is the same.No biggie I'd rather use the Digital any way it breaks the codes down into modules.
To No codes
