radar detector direct wire
Old Jan 9, 2006 | 12:10 AM
dbriana's Avatar
dbriana
Default radar detector direct wire
Has anyone run a direct wire for a radar detector where it is placed in the center of the windshied near the bottom? Is there a close and easy wire to tie into going through the dash/defroster vents somewhere or running behind it? TIA
Old Jan 9, 2006 | 12:49 AM
Slalom4me's Avatar
Slalom4me
Unless you have a windshield with the tinting that inhibits
reception, may I suggest mounting the detector to the right
of the mirror. With regular tinted glass, this places it a bit below
the bottom of the tint band.
The benefit of this is that you can draw power from the circuit
for the courtesy light in the mirror. Plus the detector is higher
so range forward (and rearward if it is a V1) is likely better. Also,
it is out of your line of sight in the shadow of the mirror.
Old Jan 9, 2006 | 08:33 AM
Da Mail Man's Avatar
Da Mail Man
this site suggests that the detector be mounted low as to increase it's ability to pick up "splatter" from speed detecting devices.
http://www.radarbusters.com/support/...detector/2.asp
Old Jan 9, 2006 | 10:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If it detects splatter, your already busted
Old Jan 9, 2006 | 10:19 AM
AGENT 86's Avatar
AGENT 86
I took power from the mirror lights
Old Jan 9, 2006 | 10:22 AM
Nathan Plemons's Avatar
Nathan Plemons
Mine is mounted in the upper left hand corner of my windshield. I mounted it there ALA "Test Drive." It may not be as effective but it certainly works and it is certainly out of the way, nobody notices that it is there. For power I just used the same circuit I used for my pillar gauges so that probably doesn't help you much.
Here's a pic
http://www.wku.edu/~nathan.plemons/g...tte/gauges.jpg
If I had a better detector in the first place I might have worried about putting it in a more optimal spot.
dbriana's Avatar
dbriana
I have the windshield with the cut out at bottom on ZR-1 for radar detectors, so I am have to mount it there.
Old Jan 9, 2006 | 10:35 AM
Da Mail Man
this may or may not be true however, if the "gun" is typically aimed where the site suggests ("low"), it may make more sense to place the detector low.
on the flip side, one could argue that mounting it "high" would elevate the detector and give it a better "view" of the road up and above (or close to it) the vehicle in front of the detector (if any) and able to detect what is "stray" or reflecting.
Old Jan 9, 2006 | 10:51 AM
Slalom4me's Avatar
Slalom4me
Specifically laser, which they cite as casting a beam of only 18" dia at
500'. (They state that radar is 85ft in dia at twice the distance.) I
had not considered this.
Since the practice is probably to aim at the body mass, even allowing
for whatever the increase in dia is at the distances (> 500') that LEOs
might target vehicles in the real world, it would seem that lower would
be better to improve chances of catching scatter from the fringes of a
small beam.
In 'over the hill' radar situations, does mounting lower reduce performance?
Does it matter? As for rearward field of view where machines have this
capability, the lower the placement, the greater the obstruction from
occupants and other objects in the interior.
As for the question of power. I have seen posts that mention routing
cords via the defroster outlet but I have no links. I'd suggest
expanding your search to include the Off Topic forum because RD
threads seem to start or get moved there.
Old Jan 10, 2006 | 10:43 PM
dbriana's Avatar
dbriana
Default direct wire tie in location
What about the wires just under the defroster outlet? Is that hot all the time or switched? It goes to a sensor that sticks up in middle of defroster outlet? what is that? Would this be a good place to wire into, ground? or should i go further under dash?
Old Jan 11, 2006 | 02:13 PM
all4c4lt4's Avatar
all4c4lt4
I mounted mine similar to Agent 86, however, mine is tucked up more behind the mirror. The "face" of the detector is almost in line with the mirror. I ran the power to the fuse panel on the passenger side of the cabin. There is an auxilary fuse that works perfectly, powers up when the ignition is on the "run" position. You can not see the power cord in the car. Just my $.02
Old Jan 11, 2006 | 03:29 PM
ckd's Avatar
ckd
I got my vette with one alredy installed and its in the lower righ corner of the instrument cluster...but it has the front and rear sensors that are under the car. Funny thing is it turns off and on whenever I turn my wipers on but remains on when I turn my wipers to high. Strange...I wonder what the rpevious owner tapped into.
To radar detector direct wire
