Air Flow Research Heads
When you're talking about stock LT1 heads it's also very rarely beneficial to go with 2.02 / 1.60 valves over the more easily installed 2.00 / 1.56 valves. You gain a little bit of upper lift flow with them but you give up a lot in the midrange which tends to result in a decreased area under the curve and thus less power. AFR's could be designed slightly differently but I'd have to see the flow numbers first.
Intake is smoother in the mid range, exhaust is quite a bit worse above .500.
All told the numbers don't look terrible by any means, they should make really good power. I'd have to compare the cost of the AFR's vs good ported stock heads before I could make a decision.
Not a big fan of AFR.... owned a set of 227's and the heads ran 10-15 degrees hotter and had oil pooling issues. It's my understanding AFR has gotten a fair amount of criticism regarding the oil pooling issue and has corrected it.
Also….. they should be coming out with redesigned heads here pretty soon as they are suppose to be revamping their entire line. All AFR LTx heads are just their regular heads converted to reverse cooling.
I'd wait for the improved ones if I were to buy AFR plus Lloyd Elliott is getting 290 cfm flow from LT1 castings and for the money, that’s pretty damn hard to beat. An aftermarket casting will flow more when ported, but unless your going for full kill……I have the stock casting ported.
thanks for the info.
If I'm not mistaken, you have a really good rapport with the TEA guys so I wanted to ask you if TEA has tested AFR heads "out of the box" and what the results were compared to advertised #'s.
If you feel answering this here will put you or TEA in a bad position, feel free of to respond PM or just maybe hint at the results or plead the 5th.
I have their 210's and will get them flow tested as part of my rebuild, I just wanted to be able to compare them to other non-AFR flow tests. I am not trying to stir anything up, this info is solely for personal use to make sure I have accurate results before deciding to/not to spend money in that area.
When I actually worked for TEA I had a set of AFR heads come across my bench and I was absolutely not impressed. First they weighed half again what stock heads weigh and the casting quality was poor. Imagine the "front" or "rear" of the head when it's bolted on the engine, one of these surfaces still had casting flash on it. Why? because there wasn't enough material in the mold and thus when the rest of the surface was machined flat there was a valley that didn't get cut. It seriously looked like complete ****. Functionally it wouldn't have affected a thing but for the cost of the heads I felt that would have been competely unacceptable.
I know at the time I made some mention of what I found on the forum and somehow that got back to AFR and they were royally pissed. The owner of TEA talked to me, he wasn't really mad, he just pointed out that I needed to be careful about what I say. Well I don't work there anymore and I still believe what I believed then. IF YOU DON'T WANT SOMEBODY TO TALK BAD ABOUT YOUR PRODUCT, DON'T GIVE THEM ANYTHING TO TALK BAD ABOUT! I am not going to lie about your product just to make you look good!
Unfortunately I can't remember at all what even happened with that head, if it went across our flow bench, etc. All I know is that I wasn't impressed with AFR's product or their company.
Instead of reacting in an "oh ****, how did that defective product leave here" manner they said "well you don't need to tell people about or defective products." It could have been a one time fluke but I'll never buy AFR because of it.
at any rate, in my case i've had no symptoms, mine's a daily driver and i've put about 7,000 miles on them so far. again, mine were not purchased direct from AFR or an AFR distributor. these are the "hybrid" AFR/TPIS heads. i may be mixing apples and oranges here, i have no idea.
In pic 2, look at the guide in the center of the 3, and note the relation of the depth of the rocker side of the pocket to the top of the guide. It comes very close to the top, and the bottom of the valve seal sits below it. Now, the problem with the AFR head is that the pocket is that deep nearly all the way around, giving the oil little room to escape. The exhaust side (low side) on an AFR head is ALSO that deep, hence, puddling around the valve seal.
EDIT: Go to AFR's site and look at the pic of the SBC 210 head. Look at the spring closest to you very closely and see how much of the bottom of it on the exhaust side of the head is buried in the pocket. That one side is open to the drain, the other end of the head is as well, but there are 14 more valves in the middle that don't have that luxury.
This is a pic of a set of Bowtie 18* heads done by Keith Dorton. Note how little area there is for oil to puddle around the spring/seal, even on the rocker side. You can even see divots around the bolt hole to allow any puddling to occur away from the valve. These heads are designed for a race car that spends hours at max RPM where oil control is a more important factor than a street head.
We do have to consider that the heads do not sit level on the engine, but, it is still clear that there is more oil in the spring pocket of an AFR head than virtually any other head. And, there is no channel along the exhaust side of the head from drain hole to drain hole. Oil is getting stuck up in the valve cover in an AFR head more than others.
how in the world can tens of thousands upon thousands of these heads be out there, and not the same number of people lining up for a refund?
Being sold on the AFR brand probably has alot to do with it. When that occurs, people start making excuses for the company and further justifying their own decision. You say you have AFR heads and everybody (almost) instantly thinks, "the best". In this context, it's really no different than how we justify all the shortcomings of our C4's as ...."character"
They are great performers, but there is always room for improvement. Maybe in their new line this will be addressed. And, as I mentioned before, the head does not sit level and driving will splash things around quite a bit.
But you're right, there is a design "quirk" that seems to serve no purpose except increasing the chances that your valve seals will leak.
