Normal Fuel Pressure Readings
Old Jan 15, 2006 | 06:03 PM
93Ruby's Avatar
93Ruby
Default Normal Fuel Pressure Readings
Hi All,
Need some help troubleshooting a hard start problem. My 93 has an intermittent starting problem--some times it starts right up and other times I have to press the accelerator a little to get it started. This problem occurs anytime, hot or cold. I just checked the fuel pressure reading a few minutes ago and was wondering if it is normal. The pressure cold, before turning key, was 0 psi and after turning the key on without starting, the pressure moved up to 39 psi. The reading running at idle is 39psi with vacuum connected to the fuel pressure regulator and 48psi disconnected. After turning the engine off the pressure was about 39psi and I only watched it for a few minutes before disconnecting and it held at 39 psi. Are these normal readings or do these readings indicate a problem? If these are normal what should be my next step in troubleshooting the problem. Thanks in advance for the help
Old Jan 15, 2006 | 06:42 PM
ittlfly's Avatar
ittlfly
Your psi #'s sound about right. Any codes?
Old Jan 15, 2006 | 07:48 PM
junk yard dog's Avatar
junk yard dog
Fuel pressure is apparently OK, but if you ever need it, there is a great article in the archives about fuel pressure--someone did considerable research and came up with real world numbers.
Click "other" at the top of the forum page, then "tech tips," then "C-4." In search block type in "fuel pressure," and look for the title "Fuel Presure Holding Numbers." Everything you wanted to know and then some.
Old Jan 15, 2006 | 10:59 PM
93Ruby's Avatar
93Ruby
No codes. Any Suggestions????
Old Jan 15, 2006 | 11:54 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Clean your TB/IAC
https://www.corvetteforum.com/techti...=195&TopicID=2
Old Jan 16, 2006 | 06:27 AM
mseven's Avatar
mseven
With reference to PSI.
Mine was similar w/out vac 48psi, w/vac 36psi. I wanted to change the strainer in tank so when I pulled it, the element was deteriorated replaced that and pump (GM stock), because pump was probably sucking in who knows what. That gave me 3 more psi at the rail and after adjusting it back to 48 w/out vac. when I put vac. back on it now only drops to 46psi.
I am not saying yours is a problem, only giving my results. Mine did not have hard starts so the pressure had no effect on my starting. I would inspect the TB, clean if nessessary.
To Normal Fuel Pressure Readings
