Interior delay timer help
Old Jan 18, 2006 | 11:38 AM
427t-top's Avatar
427t-top
Default Interior delay timer help
Wellguys, I went looking for a courtesy light delay timer and GM is out of that business...whats a fellow to do? Is there something on the aftermaket to replace these? My interior lights won't come on unless I use the light switch on the dash, they don't activate at all with the door switch..tia for any help here..
Old Jan 18, 2006 | 11:47 AM
Jerris's Avatar
Jerris
Go to www.corvettesdownunder.com Under their C4 tech page they have a nice article on how to fix the courtesy light delay timer. Hope this helps.
Jerris
Old Jan 18, 2006 | 11:54 AM
427t-top's Avatar
427t-top
Thanks Jerris but I can't get the website to come up
Old Jan 18, 2006 | 11:56 AM
kize's Avatar
kize
Try this one. They have some info on reparing your timer.
http://www.corvettesdownunder.com.au/
Old Jan 18, 2006 | 12:15 PM
427t-top's Avatar
427t-top
found it, thanks guys
Old Jan 18, 2006 | 12:38 PM
joe400's Avatar
joe400
i have the opposite problem on my 94 and the lights wont turn off for 10-15 minutes after i get in or out. i was told the timer was programmed in the computer and couldnt be changed without reprogramming the entire unit like new.
Where is the timer located and could that be all i need to solve my lighting issue. (pulled fuse right now to keep me from going batty at night)
Old Jan 18, 2006 | 04:27 PM
Jerris's Avatar
Jerris
Joe400.
Your problem is different from the one above as the 95 does not have the same timeout switch but instead is controlled by the CCM.
Your problem is either a bad passenger side door ajar switch or a bad hatch ajar switch fooling the CCM into thinking that one of these are open all the time. Open the passenger door and the hatch seperately, the one that does not make the interior lights come on is the one that has the bad switch. Just replace the door ajar switch that is bad.
TIP. You dont have to remove the door panel to change the door ajar switch. Just do a search on this forum on door ajar awitch or my name and you will find a detailed discroption of how to replace the switch that I posted. Do NOT just take the screws out and try to change it or you may loose the backing plate inside the door.
Hope this helps
Jerris
To Interior delay timer help
