Opti sucks we all no this. Its the reverse coolant flow that gets me hooked on the LT1. The ability to run high compression realiably is what I like. I run 11 to 1 no problems....The LT1 also has a better intake platform. If I am not mistaken, the stock LT1 plenum can support 500hp. These are my reasons.
I know one thing my OPTI does not suck! I wash my engine, drive in the rain, snow, ice, whatever, and I have noproblems. There may be a problem with the early OPTIs (92-94) , the OPTI was redesigned in 1995 to a vented system.
EVeryone says the L98 is better off the line, well here it is again, the timeslip between a stock LT1(just muffler eliminators) and a stock L98(a few little tweaks).
65 Z01(in the L98 can vouch for this slip.
4477 is me in my '95 six speed, 4842 is Jim in his '88 L98 automatic.
Now either the weather has a better effect on the LT1 or the LT1 is simply better, let the numbers speak.
In Germany, all stock LT1 were slower than my stock L98. Perhaps, these guys can't drive a 1/4 mile?!?
Top-speed is another thing ... pro for the LT.
Intersting, apparently the laws of pyhsics don't work over there.
In all honesty, I never did understand the "which one is better" idea.
The truth of it is, they all have a role in the history of evolution.
Every single engine is a improvement over the previous engine.
The LT1 has reverse cooling- this is an engineering improvement
The LS1 has an improved spark system to fix the optispark problem with the LT1.
The LT1 is a superior engine to the L98 - it always will be and people in this board just need to deal with it and get over it.
The LS1 is a superior engine to the LT1 and will always be. This is the natural evolution of engineering.
I am so sick of this topic
if it's such a natural evolution of engineering then why are there more go fast parts for L98 cars than LT1 cars? you know how hard it is to find a good aftermarket head for an LT1? or where to buy/build a big stroker LT1? something more than 388 cid?
hmmm....
seems to me L98 boys go faster/quicker in the long run
hmmm....
Simple, that's because compared to the standard small block (L98) engine out there, there are VERY few LTx engines so the aftermarket companies do not see the returns on making some aftermarket options for them...engine blocks being one of them. I spoke to World Castings about 2 years ago trying to work out getting a beefed up LTx block that I could take out to 427ci but they told me there just wasn't enough demand to put the time into it. But as far as heads go, AFR makes quite a few different heads specifically for LT1/4 cars...infact they make the same heads for standard SBC's as they do for the LTx engines.
great times in that LT1 but theres a problem there... an 88 L98 Auto is one of the slowest... for some reason those year auto trannys were crap... get up with a 89 ZF 6speed MUCH faster
65z01 was trapping 101 on that slip. That is a fast L98 no matter the year.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by 89vettefromhell
its 50/50 the l98 is a 1-2nd gear car but the LT1s will take top end.. i love my L98 tho... the ease of work compared to the LT1s is so much better (and not just because of Opti)
Man, you gotta be kidding! I'm working on a friend's L98 right now. I'll take my LT1 any day when it comes to working on it. I can take my intake off in half an hour w/o hurrying. Can you? Admittedly, I've made a lot of refinements on mine over stock. Even the notorious plug wires aren't bad to R&R on mine now. I'd like to take an L98 completely apart and reassemble it to see how many things I could do much more intelligently than the factory way. I can look at it and see many areas that could be easily improved as was the case on mine. I think they're both great engines. I just enjoy working on LT1s more.
True...but they can take their distributer off a lot easier than we can!!
I'd actually like to be there when you so this. I'd love to take one apart. I guess I'm just nosy...
Not sure this was an improvement since they went back to the traditional cooling on the LSx motors.
The LS1's are an all aluminum block meaning they disapate heat better and are lighter than the cast iron LT1 unit. They are also equipped with cylinder sleaves which can be overbored or stroked without normal machine work, just change the sleaves and bam!!! Correct me if I am wrong, I think this is accurate info...
I think they run out of ideas on how to improve the latest models of the LsX series so they just went with more C.I., which is fine by me!!! They may have went with more improvents but I am not sure on this.... I guess I need to read up on the C6 forum.
I ‘m not sure if the 383 stroker made much of a difference, but other than the stroker and the superram and the AFR heads and the vigilante torque converter and skinnies and slicks it was bone stock right down to the paper filter… AND those times were run with a broken antenna too!
Did you realize a Nissan Maxima has 260 hp? What does a L98 have?
Forget a Maxima, my L98 will have a 300hp Nissan 350Z for lunch...easy.
My '90 L98 runs low 13's on street tires without breaking the bank on mods. However, if I had my choice for the same $$, I'd go with the LT1. Better to start at 300hp than 250, unless your going to heavily modify it...then the L98 is a more user friendly platform.
