Hypertech coil/cap/rotor question???
Old Aug 6, 2001 | 05:51 PM
Larrym96815's Avatar
Larrym96815
Default Hypertech coil/cap/rotor question???
If I was to install this Hypertech kit on my 91 L-98 can I still use the stock aluminum cover that hides all of this? Some people say yes, some say no, I need an answer from someone who actually has tried. Thanks for any help.
Larry
Old Aug 6, 2001 | 05:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Hypertech coil/cap/rotor question??? (Larry Mackey)
It fits on my '88 L98.
The only machining necessary is to enlarge the rectangular opening in the black wire retainer that sits on top of the wire tips.
Old Aug 6, 2001 | 05:58 PM
h rocks's Avatar
h rocks
It fits my '90 fine without any modification.
Old Aug 6, 2001 | 05:59 PM
Larrym96815
Default Re: Hypertech coil/cap/rotor question??? (65Z01)
65Z01,
Thanks for the quick reply. By "machining" do you mean something I can do with a Dremel tool or do I need a machine shop? Thanks again.
Larry
Old Aug 6, 2001 | 06:01 PM
Paul G's Avatar
Paul G
I just installed one on my 88. I ordered the trimmed cover from corvettecentral.com abiout $20. The stock cover would have fit. Would have touched the cover or at least been very tight. I wanted the Hypertech coil to show. (It has a cool tag on it) .
Old Aug 6, 2001 | 06:12 PM
65Z01's Avatar
65Z01
Larry, I used the term "machining" loosley. I used a Dremel cutter to remove necessary material inisde the rectangle and a sanding drum to smooth it out. Anyway, mine is under the Al plenum tail piece for that "stock" look.
To Hypertech coil/cap/rotor question???
