88 braking force
Old Jan 28, 2006 | 04:17 PM
Da Mail Man's Avatar
Da Mail Man
Originally Posted by CentralCoaster
Those new imports have more power assist for driver comfort, for more line pressure (and less brake surface area). All that means is a Corvette driver has to push the brakes harder. I could pull my 85 vette down from 60 mph in less than 130 feet with stock brakes; this is on par with most new small cars. I bet the 88 would do even better, I think GM improved the bias, not to mention the ABS if you get too carried away.
...i see, however my 81 blew my 88 away in braking force after i replaced the proportioning valve (stock). i never "bedded in the pads/rotors or anything fancy on it.
...this is a nagging problem that i have read that others had with their c-4's. it is back to the starting line to first replace the now leaking m/c, bleed it, then the whole system again (at this rate i will need a 55 gal drum of brake fluid!) and see what happens.
Old Jan 28, 2006 | 05:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
This would all be much easier if you had speedbleeders. I don't see nearly as many compliants about the 84-87 brakes. Not sure why.
Old Jan 28, 2006 | 05:51 PM
Da Mail Man
DEFINITELY not an issue with speed bleeders WHATSOEVER . ya need to re-read the post(s).
Old Jul 23, 2020 | 08:19 AM
Da Mail Man
I just figured that I would get back to this as I have forgotten all about this post....Bottom line - I was bleeding my brakes (and a shop did too) the typical way most of us have learned. Starting with the line/wheel farthest from the MC...WRONG!
I read the HELMS and it had a totally different bleed pattern then what I and a shop did! I followed that bleed pattern and had good brakes since, until I blew a rusted brake line. There is another post for that with picts if I already haven't moved/deleted the picts.
