Roller into 85 block
Old Aug 7, 2001 | 08:45 PM
GRX's Avatar
GRX
Default Roller into 85 block
Gents,
I want to install a roller cam into my 85 block. I understand I need aftermarket roller hyd lifters but will a 1987 L98 roller cam fit my block?
I want a roller to pep things up a bit but also want to pass smog.
Any ideas welcome! :smash:
Old Aug 7, 2001 | 09:53 PM
Chris@SD's Avatar
Chris@SD
Default Re: Roller into 85 block (GRX)
You will need the following parts:
Comp Cams lifters PN: 853-16
Pushrod length: 7.290
Better Springs!
If you are going to go through this much trouble, you might as well get a better cam than a stock '87 cam. We custom make cams and have quite a few that will boost power very well and pass emissions, but they are billet cores and probably a little more than you need. There are also a wide range of shelf cams that you can get that will pick up power output a bit more than the '87 and pass emissions.
Good luck,
Old Aug 7, 2001 | 10:24 PM
vettpunk's Avatar
vettpunk
Wouldn't you also need a cam button or retainer
plate to keep the cam from walking forward? Is a torrington bearing or fiber thrust plate needed behind the cam gear? Should you check the clearance between the cam button and the front timing cover? What chain/gear set is required? Any other details?
Vettpunk :conehead
:conehead
Old Aug 9, 2001 | 01:56 PM
Greg Johnson's Avatar
Greg Johnson
GRX,
It will fit, but you will have to have your block bored for the roller bearings. then replace lifters, pushrods and lifters.
Gregor
Old Aug 9, 2001 | 07:58 PM
Chris@SD's Avatar
Chris@SD
Default Re: Roller into 85 block (Greg Johnson)
GRX,
Gregor
Comp Cams makes retro-fit roller lifters that require no machine work. You will not have to midify the block.
Old Aug 9, 2001 | 08:26 PM
Mr. G.'s Avatar
Mr. G.
You'll need the roller cam, retro-fit roller lifters, pushrods (to do it right, you have to check them with a length checker), late style (roller) timing set, and a cam button.
Hope this helps.
Joe
To Roller into 85 block
