Major Brake Problem.
Old Feb 7, 2006 | 04:01 PM
Dan C4-C6's Avatar
Dan C4-C6
St. Jude Donor '06-'07
Default Major Brake Problem.
How do I know if I should change the Brake Booster or the Master Cylinder or something else? Here's my problems: rock hard brake pedal, car barely stops even when brakes are FULLY pushed, when ever I press the brake pedal my idle changes and my headlights/interior lights dim quite a bit.
NOTE: I changed my brake pads, rotors, and bled them and still nothing.
Old Feb 7, 2006 | 04:18 PM
TimV SR's Avatar
TimV SR
The only connection between brakes and idle speed is vacuum via the booster. Sounds like a bad booster to me.
hz900's Avatar
hz900
Been there done that..... if it takes both feet to fully depress the brake pedal while driving, you're booster has went out or the vacuum line going to it has a leak or has come loose, although the latter would also make the engine run like crap because of the vac. leak it would create.
Old Feb 7, 2006 | 04:43 PM
MarkBychowski's Avatar
MarkBychowski
Booster
Old Feb 7, 2006 | 05:27 PM
Dan C4-C6's Avatar
Dan C4-C6
Thanks guys for your help. I kinda thought it was the Brake Booster a while ago but I wasn't sure,but now I am going to get a new METAL one A.S.A.P.
To Major Brake Problem.
