best crate engine
Old Feb 8, 2006 | 04:37 AM
Aussie Vet's Avatar
Aussie Vet
Default best crate engine
What would be the best crate engine to have an easy fit into an 89 6speed using a mini ram intake. must be at least 383ci . Already considered zz383 but was curious what else is out there, any suggestions will be appreciated, thanks.
Old Feb 8, 2006 | 07:07 AM
rodj's Avatar
rodj
How much you want to spend?
Any small block is a "easy" fit.
American Autos in Homebush have a Hardcore 454 small block
for $A18K.600Hp
Eagle spares have the Fastburn 350 / 385Hp for $A8K
Old Feb 8, 2006 | 08:49 AM
Slalom4me's Avatar
Slalom4me
Originally Posted by Aussie Vet
What would be the best crate engine to have an easy fit into an 89 ...
A question to ask about any of the candidates on your list is what
diameter damper is assembled on the crank.
A choice like the ZZ383 comes with an 8" OD damper and this requires
chassis mods or replacement of the damper with a smaller dia unit.
Feasible, but perhaps not a trival consideration for someone in your part
of the globe.
Old Feb 9, 2006 | 12:11 AM
Aussie Vet's Avatar
Aussie Vet
thanks guys.
Anyone else know of any?
Old Feb 9, 2006 | 10:41 AM
C-4 Now's Avatar
C-4 Now
Will have to be a buildup using late style one piece rear main seal and matching late model crankshaft to continue using your ZF flywheel and clutch assembly. Limited choices besides ZZ383
Old Feb 9, 2006 | 11:03 AM
GeosFun's Avatar
GeosFun
http://diabolicalperformance.com/ Check these out. Dave has a C4 with 427 himself so he knows what parts fit and which do not on any configuration you want. I recently had him build a 406 specifically configured to pass Ca smog and still make good power. It is in the car now and just waiting for a new fuel pump, due in tomorrow I can't wait to get it dialed in so I can report back in these boards.
Old Feb 9, 2006 | 11:18 AM
MrNuke's Avatar
MrNuke
Tell them to fix their damn website..
Old Feb 9, 2006 | 11:36 AM
GeosFun's Avatar
GeosFun
What problem are you having with it? I can get around on it fine??
Old Feb 9, 2006 | 03:23 PM
VenkmanP's Avatar
VenkmanP
http://www.gmpartsdirect.com/results...partnumber=LS7
Old Feb 9, 2006 | 05:08 PM
MrNuke's Avatar
MrNuke
Yeha good luck with the swap on that one.. I think he is looking for something tha twon't take an act of god and 1/2 a year and a fortune to install... Liek most of us..
To best crate engine
