recomendation for header gaskets/LT4
Old Feb 10, 2006 | 05:41 AM
vstol's Avatar
vstol
Default recomendation for header gaskets/LT4
Looking for recomendations for a header gasket for a LT4
Old Feb 10, 2006 | 07:56 AM
96 lt-4's Avatar
96 lt-4
i used fel-pro.have had good luck with them for years.don't remember the part #,but it is lt1/4 specific.
Old Feb 10, 2006 | 08:32 AM
aboatguy's Avatar
aboatguy
I like my Percy's deadsoft aluminum header gaskets!
Old Feb 10, 2006 | 09:57 AM
tjwong's Avatar
tjwong
Or you can use felpro 1406
Old Feb 10, 2006 | 11:14 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I'm real happy with Percy's dead soft aluminum ones also. There is a new company just getting started, I talked with one of their reps at a drag racing show a couple weeks back. The name is Flatout Gaskets, you can check them out at www.FlatoutGroup.com. I plan on trying them if I ever need another set for my car. Keep in mind that no matter what gaskets you get you have to run them through at least 3 heat cycles with re-tightening after each cool down to make them last.
Old Feb 10, 2006 | 12:56 PM
mseven's Avatar
mseven
I am using fel-pro right now but if I had to do it again I would use these, you would need port size. Check these out.
http://www.holley.com/data/Catalogs/...%20Systems.pdf
Old Feb 10, 2006 | 01:54 PM
STL94LT1's Avatar
STL94LT1
Old Feb 10, 2006 | 07:00 PM
vstol's Avatar
vstol
I talked to the rep at Flatout and they recomended to stay away from the aluminum ones and stick with the copper with the rubber coating. I think I will go with that one #7067C
Old Feb 10, 2006 | 07:05 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I use OEM factory gaskets for the cast iron manifolds, right now. No leaks with my DRM stainless steel headers, and my bolts havent backed out.
Old Feb 10, 2006 | 07:20 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Hey Steve good to see you decompressed and came back.Have any good dougnuts lately?
Old Feb 10, 2006 | 07:42 PM
steve40th's Avatar
steve40th
Just creamed filled
Old Feb 10, 2006 | 10:39 PM
ninetyfivevette's Avatar
ninetyfivevette
A little off topic, but relevant at the same time... Anyone ever get their header flanges ground for flatness? Seems my EM headers go through a lot of gaskets, even with proper torquing/retorquing sequences. I've had better luck with the Felpro 1406, but still can't get a good seal (can see where exhaust has escaped).
To recomendation for header gaskets/LT4
