Torque Converter Question
Old Aug 11, 2001 | 02:51 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Torque Converter Question
How do you know if it is working correctly....like locking up, or not locking up......
what happens if it does not lock up....or won't disengage?.....what would the car feel like.....
just curious.....
Old Aug 11, 2001 | 03:17 AM
Jimi Lane's Avatar
Jimi Lane
Default Re: Torque Converter Question (XtremeVette)
Drive down the road and let it everything get stabilized at a certain speed. The converter should be locked up at this point. Keep your foot on the gas pedal and press the brake pedal with your other foot. The converter should unlock when the brake is pressed. It may feel kinda like the tranny downshifted. Take your foot off the brake and the converter will lock up again, as long as you're not going up a hill or gave it more throttle. Also, you need to be in overdrive, but don't hit the brake or gas enought to make it actually shift out of overdrive. This is the way it works with my '93 anyway.
jimilane
[Modified by Jimi Lane, 1:17 AM 8/11/2001]
[Modified by Jimi Lane, 1:19 AM 8/11/2001]
[Modified by Jimi Lane, 1:55 AM 8/11/2001]
Old Aug 11, 2001 | 08:53 PM
jpee's Avatar
jpee
Default Re: Torque Converter Question (Jimi Lane)
Your converter wont lock up until app 44 mph... once its locked, you drive about 50, & let off the gas the tach should stay at the same RPM if its locked.. if the tach drops 200-300 rpm you know its unlocked..
I will lock in D or in OD at app 44-48 mph.. under that speed it wont lock..
Old Aug 12, 2001 | 03:26 AM
CROOZN's Avatar
CROOZN
I am running the 3000 stall Vigilanti with 3:55 gears, mine locks up at 35mph with Ed Wright's programming.
Old Aug 12, 2001 | 04:35 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Connect a test light (like a mini LED in series with a 2.2k Ohm 1/4W resistor) across ALDL pins A and F. When the light goes out the ECM has sent the Lock-Up singnal to the TC solenoid.
To Torque Converter Question
