TPI porting
Old Feb 27, 2006 | 08:09 PM
black85vette's Avatar
black85vette
Default TPI porting
Has anyone done the porting to there TPI intake --siamese ports-and opening up the center plenum? I have some questions..
Old Feb 27, 2006 | 08:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
http://forums.corvetteforum.com/show...ed&forum_id=48
Old Feb 27, 2006 | 08:31 PM
Insane1's Avatar
Insane1
Yes, I siameased and port matched my plenum/runners/intake and it was good for about 25lbs rwhp and 21lbs rwtq on the dyno
Old Feb 27, 2006 | 08:53 PM
black85vette
Default intake
Where the runners bolt to the intake how deep did you cut down the center web between the ports? I am thinking of going down 2" deep and about 3/4" tall and then radius the edge of the cut. Can you explain what you did?
Old Feb 27, 2006 | 09:15 PM
black85vette
Can any one else shed some light on this?
Old Feb 27, 2006 | 10:16 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Not calling b.s., but I'd like to see that.
Anyhow, I siamesed the plenum and dremel'd these out.
Old Feb 27, 2006 | 10:19 PM
crossfire7's Avatar
crossfire7
You might get some answers if you post what your questions are.
Old Feb 27, 2006 | 10:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Central Coaster, you spent some time on that! Looks good, now come and do mine. I will pay you in dirty socks and kitty litter
Old Feb 27, 2006 | 11:53 PM
CentralCoaster
How about I send you my new (new to me) edelbrock base and untouched set of stock uppers, and a blank rubber check? You got all the tools man.
Old Feb 28, 2006 | 12:02 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Only reason I believe that is your profile says you got a 383 engine.A tpi is starving its potential and opening it up will feed it more air that it needs.
On a stock engine youre not going to see anything,and if youre lucky maybe a few ponies.
Old Feb 28, 2006 | 12:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
Bring it!
Hey, how did you get your head inside the plenum in that picture? Cool view.
Old Feb 28, 2006 | 01:53 PM
JAKE's Avatar
JAKE
I'm running a set of aftermarket runners and I removed the dividing walls in as far as I could possibly reach using a long metal saw-all blade.
I actually wanted to COMPLETELY remove the dividing walls, but couldn't get the blade to turn the corner right near the center of the runners. The only way to get to that area would be to cut a section out of the runners, remove the walls behind that section, then weld it all back up.
Going from memory, I believe my runners still have about 1-1/2" of dividing wall remaining. All the rest is long gone (siamesed).
I did pretty much the same thing with the intake manifold, leaving about 2" of wall remaining just before the intake manifold runners meet the cylinder heads.
I remember writing down all the numbers as I did the porting and may have them around here, somewhere. If I come across them, I'll post them.
Jake
Old Feb 28, 2006 | 05:27 PM
black85vette
OK if a person was to remove the sheet metal cover off of the bottom of the intake. And set up a jig on the mill table to lay the intake on its side, clamp it to the jig.then drop down inside the round ports that feed the opposite side of the engine. How deep did you cut into the web between the ports?
Old Feb 28, 2006 | 05:37 PM
CentralCoaster
I think siamesing the 5&7 tracts is a terrible idea.
Old Feb 28, 2006 | 05:40 PM
black85vette
Thanks Jake you were very helpful.
Old Feb 28, 2006 | 05:50 PM
comp's Avatar
comp
Old Feb 28, 2006 | 09:03 PM
Insane1's Avatar
Insane1
I will post the dyno scans when I get home tonight.
To TPI porting
Old Mar 1, 2006 | 03:20 AM
Insane1's Avatar
Insane1
Before...
After...
Ok, so I was a little off. Only 21 rwhp and 14 rwtq. Shoot me for not remembering correctly.
And no comments about the pathetic numbers I am putting out with this motor. What would you expect from a 8:1 motor? I plan on putting flattops in it and hopefully bringing the compression up to about 9.5:1
Old Mar 1, 2006 | 07:40 AM
leolhaudek's Avatar
leolhaudek
Default T.p.i. Porting
Nice job,,I plan to do the same plus fill all those egr ports that are in the intake, with furnace compound which is like bondo then when put in oven it gets rock hard so all egr ports are soild no heat.. The air / fuel goes only down intake chambers..Just a thought Will It Work???? Will this help Please Respond Thank's Leo
Old Mar 1, 2006 | 11:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
Leo, I was told to use evercoat (?!), a fiberglass bondo in a wet/dry intake by a prominent porter out here to fill small holes, divots, things like that. Gas and heat doesnt affect it. Ill talk more with him tonight on it.
