IAC Gasket
Old Mar 1, 2006 | 08:43 PM
Performance nut's Avatar
Performance nut
Default IAC Gasket
I did a search on the forum and found a link to Rock Auto. I searched around and found a gasket kit (Under Fuel/Air, TBI gasket kit): Standard Motor Products Kit #2009. When I looked at the kit (more info button), it shows the six gaskets that it comes with. The small round one is the IAC gasket, correct?
BTW, if someone knows somewhere I can order just the IAC gasket, I would appreciate the link/phone number. Thanks.
Old Mar 1, 2006 | 09:01 PM
87vette's Avatar
87vette
Yes that is correct. You can buy the whole TB kit at an Auto parts store for like 15 dollars. I keep the other gaskets on the side in case I need it for future use.
Old Mar 1, 2006 | 09:34 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Cut your own gasket. Should take about a minute and a half
Old Mar 2, 2006 | 02:32 AM
Morley's Avatar
Morley
You hardly ever remove the other parts on the TB but the IAC is one that seems to be removed a lot (cleaning, replacing etc.) So I just make a new one myself from gasket material from the parts store.
Old Mar 2, 2006 | 06:20 AM
Performance nut
That actually isnt a bad idea. Need to look around for comparable gasket material in the area. I shouldnt need anything heavy duty, something like this ya think?
http://www.acehardware.com/product/i...archId=1258971
Old Mar 2, 2006 | 07:07 AM
Lars87's Avatar
Lars87
I did that...
Old Mar 2, 2006 | 08:18 AM
AGENT 86's Avatar
AGENT 86
I would look for something a little thicker for the IAC. That 1/32'' stuff is more suited to machined/mounted installations.
To IAC Gasket
