Help! SYS No start
Old Mar 3, 2006 | 04:54 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Default Help! SYS No start
After starting her up and driving for a short time the "service ASR" light comes on and the security light and SYS flashes, If I turn off the ignition, it will not re-start. A couple of times I left the car then returned, and it would fire right up. Other times the security light and SYS would stop flashing but the ASR light remains on, but I turn off the car and it will start right away. ant thoughts???
Old Mar 3, 2006 | 08:00 PM
redvette30's Avatar
redvette30
5th Gear
It could be the security code on the key and or the ignition switch.
My wife's firebird had the same problem.
Old Mar 3, 2006 | 08:04 PM
jfb's Avatar
jfb
The SYS light came on so there are stored error codes. What are they?
Old Mar 3, 2006 | 09:00 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The SYS light may be caused by a bad battery.When was the last time it was changed?What voltage is the gauge reading at idle?Either way it is an electrical issue.
Old Mar 5, 2006 | 12:05 AM
blacker's Avatar
blacker
Default Won't start
Check the battery, security chip in the key, MAF and any fusible links from the MAF to the ECM.
Old Mar 5, 2006 | 12:29 AM
DDSLT5's Avatar
DDSLT5
Bad battery - get a new battery, problem solved!
To Help! SYS No start
