Plug wires HELP!
Old Aug 12, 2001 | 11:59 PM
Larrym96815's Avatar
Larrym96815
Default Plug wires HELP!
I always thought changing plug wires was a 20 minute job. Those were the old days! I decided today to put on my new Taylor wires from Chris at Speed Demon. Well one hour later I am still trying to figure out how to get the first plug wire off. It goes under, behind and around the distributor. How do you get the old one out of there? It is fastened some where that I can't even see. If I was to get the old one out how would I ever get the new one back in the same location? Do most of you route the new wires in an easier location? Any help is much appreciated.
Aloha,
Larry
Old Aug 13, 2001 | 01:16 AM
Warlock's Avatar
Warlock
Default Re: Plug wires HELP! (Larry Mackey)
Take the cap off with the wires attached, swap the wires and put it back.
Old Aug 13, 2001 | 08:52 AM
Forrests90's Avatar
Forrests90
If you haven't done so already the first thing that you need to do is take the extension off the back end of the plenum by removeing the three torx bolts on top. Then you can see how things go, it is pretty easy from there.
Old Aug 13, 2001 | 09:10 AM
nickd's Avatar
nickd
Default Re: Plug wires HELP! (Forrests90)
Is the wire hung up ? I think there is a clip holding the wires back there.
Easiest thing to do would be to cut the old wire if you can't get it out.
Old Aug 13, 2001 | 09:27 AM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
I think you are talking about the actual routing of the wires around the back of the cyl heads, right?
I'm sorry to say that there is no easy way to do this. If the wires have been changed correctly, they will be held in place around the lower lip of the heads by some retainer clips that need to be released. There will be some conduit around some of the wires, where it goes around the back of the cylinder head, and they are held in place by a few metal shrouding peices. I never liked this design, I think it causes premature chafing and arching of the wires, so I got some wire looms that go over the valve covers. I liked how they looked until I broke one during the engine rebuild (don't ask how...)
Take your time and good luck.
Old Aug 13, 2001 | 11:28 AM
Vic'89's Avatar
Vic'89
First remove the Plenum extension cover. Now you will be able to see all the wires on the cap. Pull & replace 1 wire at a time. Wait till you try to remove the wires on the plugs on the passenger side, those are a little difficult.
Are you changing plugs also ?
Vic
Old Aug 13, 2001 | 02:09 PM
Larrym96815
Thanks everyone for the help. However I have removed the top cover piece. I can't take off the cap with the wires attached because the wires prevent me from lifitng it. Some of the wires are fastened some way behind and under the distributor. I can pull the one plug wire from both directions and feel it but it won't move and I can't see what is holding it. There is no way a new wire will fit in the same place without attaching one of the ends after the wire is inserted through the hole. The wiring is factory original. I am thinking of just cutting off the old wire and routing the new one in a different area. Any more ideas?? Thanks again.
Aloha,
Larry
Old Aug 13, 2001 | 02:24 PM
smallblock's Avatar
smallblock
cut the old wires one at a time and replace them. I'm sure you can figure out a "nice" route for the wires. :jester that's what I did. It takes a while so be patient :crazy:
Old Aug 13, 2001 | 08:51 PM
vettenuts's Avatar
vettenuts
Larry,
There is a bunch of stuff behind the distributor. Get some masking tape and mark them, and use a felt tip to mark the distributor. Take all the wires off the cap and then remove the cap and rotor. You should now have better access to the wires. I did a little modification on mine and didn't install all the factory clips. I instead used some of the split plastic corrogated tube on the driver's side and routed them in the same location but didn't clip them.
Old Aug 13, 2001 | 11:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe there is a wire loom at the rear of the valve cover and it may have a snap cover.
I cheated by doing the wires at the same time I put in the HyperTech coil/cap/rotor and used the stock routing and wire looms.:cool:
If you opt for this method, put some Liquid Wrench on the bottoms of the four dist bolts before you try to remove them. It will prevent you from snapping off those little guys inside the dist base. Then use some anti-seize when installing them back.
BTW, you haven't gotten to the fun part yet. Check out the routing under the EGR tube!:cry
Old Aug 14, 2001 | 12:38 AM
R23HTC's Avatar
R23HTC
Default Re: Plug wires HELP! (65Z01)
Be thankful you don't have a LT-1 and end up spending ALL DAY doing a wire change! :jester
Old Aug 14, 2001 | 04:07 AM
Larrym96815
Okay guys, thanks for all the help. I found the clip on the back under side of the distributor holding three wires together. It was holding wires going both directions so I couldn't pull them out. I finally got at it with needle nose pliers and unhooked it. After that it was no big deal. Thanks again for the help.
Aloha,
Larry
To Plug wires HELP!
