i think I saw a mini ram for like $850 in the parts section. What are you trying to achieve with you motor? What mods do you have? What gears do you have? Do you have the stock computer? Everything has to work together.
If you only want to change the cam with a pretty much stock set up you should go with something like this zz9 but gears and a stall converter still would probally be needed
I have a cat back borla right now. and little stuff like the fribree removed and little stuff. i have the stock 3.54 in the back (don't have plans on changing) and 6 speed trans. I what to get in the 350hp - 400hp range. Is that price with the fuel rails?
I'm sorry I thought it was Summit I purchased the covers from. It was Jegs. I bought so much on this "limited budget" I can't remember from wence things came. These are center bolt covers and really nice. Jegs Part # is 555-50104.
what if i don't want to change my tune port out, and i get an after market intake manifold and runners how would that be? and what kinda gears are we talking?
optimally you would want 4.10s with a LT1/MR intake
going to the modified TPI setup brings different cams into play, as the hotcam is not made for it and doesnt suit it well, you need to look at my website
