oil temp sender
Old Mar 9, 2006 | 03:04 AM
hezi's Avatar
hezi
Cruising
Default oil temp sender
The oil temp sender on my 1995 c4 is broken.
Anybody have the part# ??
Old Mar 9, 2006 | 05:12 AM
The Bus's Avatar
The Bus
I just went to Advance Auto Parts and bought a new one didn't need a part #
Old Mar 9, 2006 | 07:03 AM
hezi's Avatar
hezi
Cruising
Ok,that was easy,but you see I live in Denmark and I have to order all my parts i the U.S.
I have my list ready,the only thing I haven`t got is the part# for that dam.... oil temp sender.
Looked everywhere can`t find the #
Old Mar 9, 2006 | 09:44 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Hey, buddy-ro. The GM PART # is 25036935. Take care.
Old Mar 9, 2006 | 12:31 PM
hezi's Avatar
hezi
Cruising
thanks a lot
Old Mar 9, 2006 | 12:35 PM
hezi's Avatar
hezi
Cruising
just checked the number,looks like it`s a oil pressure sender and not a temp sender
Old Mar 9, 2006 | 02:03 PM
onedef92's Avatar
onedef92
Are you certain? When I went to GM Parts direct this is what I came up with
http://www.gmpartsdirect.com/results.cfm
GM PART # 25036935
CATEGORY: Engine Oil Pressure/Temperature Hardware
PACK QTY: 1
I even called two local Chevy dealers to be sure. Hmmmm.
Old Mar 9, 2006 | 07:10 PM
hezi's Avatar
hezi
Cruising
when the two local chevy dealers says it´s a temp sender ,I`ll take theyre word for it.
Thank you very much for your effort.
Old Mar 10, 2006 | 10:54 AM
onedef92's Avatar
onedef92
No problem. Are you seeing lazy gauge syndrome? Temp guage only moving partially even after engine oil reaches normal operating temps, right? It's a common C4 issue. I need to replace mine myself.
Tell you what. When I purchase one, I'll double check the numbers on it and let you know. You'll probably have yours in hand by then, though...
To oil temp sender
