Quick TB question
Old Mar 9, 2006 | 03:31 PM
js292's Avatar
js292
Default Quick TB question
Can someone tell me if there are any o-rings in the TB on a 85. Not sure if there are any on the butterfly shaft or anywhere else.
I was going to soak it in solvent but the solvent I use hates rubbber
Old Mar 9, 2006 | 10:41 PM
js292's Avatar
js292
Anybody take their TB all the way down?
Old Mar 10, 2006 | 01:52 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
take it off, and use TB cleaner and a tooth brush to clean it. then polish with mothers... looks great.
Old Mar 10, 2006 | 07:36 AM
Morley's Avatar
Morley
No, there aren't any O rings in the throttle body (TPI or LT1) unless you've had the bearing "upgrade" done. There is, however, a 2 piece plastic spring tension device at the throttle arm end (big black thing where the spring is) so, if the solvent you use doesn't like rubber, chances are it will weaken or destroy the plastic.
I've done the bearing "upgrade" on several TB's and I tear them down before putting any solvent on them (soak em in parts cleaner).
Old Mar 10, 2006 | 09:24 AM
js292's Avatar
js292
Thanks guys
To Quick TB question
