Smoke on Acceleration
Old Mar 10, 2006 | 08:38 PM
larrynash's Avatar
larrynash
Default Smoke on Acceleration
My 95 LT1 has been smoking for years on wide open throttle. I've replaced wires, opti cap, plugs and O2 sensors. Most recently I cleaned the throttle body n replaced the gaskets and checked fuel pressure. Mileage is 140 k and fuel economy is poor on the highway (about 20 MPG). Idle is smooth and there are no codes. Can anyone help??
Old Mar 10, 2006 | 09:01 PM
Morley's Avatar
Morley
What color is the smoke? Blue, black or white?
Old Mar 10, 2006 | 09:07 PM
larrynash's Avatar
larrynash
Default smoke color
It isn't oil (blue). It is gas. I didn't mention it never burns oil and passes NJ state emissions without a problem every time.
Old Mar 10, 2006 | 10:03 PM
Morley's Avatar
Morley
Might have an injector (or more) leaking. Try running some Sea foam through it and see if it helps.
Old Mar 11, 2006 | 10:31 AM
larrynash's Avatar
larrynash
Default Fuel Cutoff
I picked up some Seafoam this morning. Does anyone know when the ECM cuts off fuel flow? Is there a chance the transmission is shifting too high? Would fuel cutoff cause puffs of smoke?
Old Mar 11, 2006 | 04:53 PM
Morley's Avatar
Morley
don't know about the 95's but the 93 LT1's fuel cutoff is set to 5851 rpm.
To Smoke on Acceleration
