I think my rpms are about 6100-6200 but I am still using the factory tach. I will see if I have any datamaster readings to give you a better idea. See times below.
Thats about where the calc put it, low 6k range. Sounds like 4:09's are going to be a bit much for me. You guy think a valve spring and rocker change (1.6) will be enough for a L98 to pull to there?
