Code Reader for 85 Corvette?
Old Mar 16, 2006 | 08:49 AM
dsimon55's Avatar
dsimon55
Default Code Reader for 85 Corvette?
I have been thinking about geting a code reader. It will primary be for my 85 vette but I also have a 2004 Tahoe.
Anyone have one they like or would recommend?
I dont want to spent a fortune on it.
Do these ones that hook up tp laptop work well?
How about code updates for the newer cars?
Thanks for the help
Dave
dbs_55@yahoo.com
Old Mar 16, 2006 | 09:07 AM
rick lambert's Avatar
rick lambert
two different systems-one won't work for the other.Most guys just use a paper clip on their earlier C4s. Code readers are fairly cheap-but that's generally all they do. If you want a scanner-one that hooks up to a laptop then you can log data-showing if sensors etc. are within
parameters. My advice -learn how to obtain (paper clip) and read codes on your 85-very simple. As for the Tahoe-hope others chime in.
Old Mar 16, 2006 | 09:18 AM
comp's Avatar
comp
Old Mar 16, 2006 | 10:48 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
There's code readers
and scanners scan/tools.
Then there's OBD1 (your vette) and OBD2 (your Tahoe)
Your tahoe might be able to show you codes without any tools, it usually means cycling the key on/off a few times and holding the odometer reset, or something like that.
Your vette needs a paperclip.
Old Mar 16, 2006 | 12:08 PM
blown87's Avatar
blown87
GA Events Coordinator
Buy a used Snap-On scanner (brick), many pro's are going to the "Modis" so you should be able to get one cheap, do not get one with a cartridge for any thing later than a 95.
If you can buy one with out a cartridge i think i might have a cartridge that will work for your 85.
For your 2004, you are going to need a current cartridge for that.
I can find out for you what it would cost for just the US only version with and with out the trouble shooter if you would like.
It will not go out of date because the cartridges are flash up gradable and are a very good tool.
Greg N
Old Mar 16, 2006 | 08:23 PM
dsimon55's Avatar
dsimon55
Default 85 code reader
How do I use the paperclip??
any tech articles on it?
thanks
dave
Old Mar 16, 2006 | 08:37 PM
LS6 Motor's Avatar
LS6 Motor
Actron makes a nice scan tool that will read both OBD I + II. You just need an additional connector that is $30.00, and the scan tool was $199.00 at Advanced Auto. I use this on both my 2004 Chevy Colorado, and 1991 Corvette. They have a website to look at their various products, just do a Google search on Actron.
Old Mar 16, 2006 | 10:08 PM
goldeneye_vet's Avatar
goldeneye_vet
thanks
dave
The paper clip method is very easy.
1. Bend a paper clip into the spape of a U.
2. Remove the cover (if you still have one) of the ALCL connector underneath the driver's side dash and plug them into the the top two connectors closest to the tranny tunnel. They are labeled A and B.
3. Turn the key to on(not running) and look at the service panel for the check engine light. It will be flashing. The first three signals will be 1 and 2. Each one will blink 1 for 1 and 2 for 2 with a pause between the 1 and 2. The next set of codes will be the trouble code. Again you'll see the 1 and 2 and then a pause. If the code is 33 you'll see the light flash 3 times quickly and a pause then 3 more flashes quickly. When the last of the codes is done you'll see the 1 and then the two flashes and then the process will start over again.
Although this is the basic method of getting the codes you'll still need to understand what they mean so you're next best bet is to get a FSM from www.helminc or look on ebay for a used manual. For the Helm you can't beat the troubleshooting charts as they are extremely helpful in tracking down the problem. Good luck!
Old Mar 26, 2006 | 02:59 PM
dsimon55's Avatar
dsimon55
HI Greg
well I got a mt2500 snap on scanner from ebay.
wondering if you ever found the cartdrige?
also might you have any other parts or manuales for it?
thaks
Dave
dbs_55@yahoo.com
Old Mar 26, 2006 | 04:25 PM
blown87's Avatar
blown87
Yes i have found some, i just posted what i have in scan and tune.
Look at what i have, find out what you want then send me a pm and we will see what we can do.
Greg N
Old Mar 26, 2006 | 05:47 PM
RRT vette's Avatar
RRT vette
Paperclip
Old Mar 27, 2006 | 02:06 AM
JoBy's Avatar
JoBy
WinALDL works for your 1985.
http://winaldl.joby.se
Old Mar 27, 2006 | 11:25 PM
Insane1's Avatar
Insane1
Anything in the works to make WinALDL work with a '90 Vette?
Old Mar 28, 2006 | 11:36 AM
JoBy's Avatar
JoBy
No. WinALDL only reads the old 160 baud format. Craig Moates software should work for you.
Old Mar 28, 2006 | 11:57 PM
Insane1's Avatar
Insane1
Darn. I think yours is better
To Code Reader for 85 Corvette?
