Ecm
Old Mar 16, 2006 | 10:04 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Default Ecm
I'm trying to find a ECM for my 86 coupe. I posted in C4 parts/wanted, but received no reply. Anybody know where I could find one.
thank you.
Old Mar 16, 2006 | 10:55 PM
rick lambert's Avatar
rick lambert
NAPPA, Autozone etc. some guys like the NAPPA best.
Old Mar 17, 2006 | 03:28 PM
zaragoza's Avatar
zaragoza
Thank you sir.
Old Mar 19, 2006 | 08:00 PM
redrose's Avatar
redrose
junkyards are loaded with 4 cylinder S-10 pick-ups around 1989 that used the -165 ecm...usual price $25 if you pull, $40 if they pull...its located in about the same place as the vette but pull down the hush panel (if its still there) and one 7mm screw and the computer falls on the floor...must reuse the chip from the vette
i've got a spare if you want it--$30 plus shipping
Old Jun 11, 2006 | 06:52 PM
rachels's Avatar
rachels
Default What It Is
IS I BOUGHT MINE 4 70$ @ AUTO ZONE, BUT BEWARE; ONCE
YOUR THROUGH THE DOOR, ITS YOURS. NO RETURNS!
Old Jun 11, 2006 | 10:36 PM
RRT vette's Avatar
RRT vette
I've seen them on Ebay for about $80 with the eprom. At auto parts stores you will need to remove the old eprom to install in the remanufactured ECM.
Old Jun 16, 2006 | 08:51 AM
anesthes's Avatar
anesthes
thank you.
I'll be pulling the '165 out of my '87 in a day or so (repinning to '730) so it will be for sale if you want dibbs. memcal included.
-- Joe
Old Jun 17, 2006 | 06:33 PM
reachnstar's Avatar
reachnstar
4th Gear
I found this thru Eckler's
1986-89 Electronic Control Module
Remanufactured By Delco
Save Big Money Versus New
Reuse Existing Chip (Not Included)
Note: Remove PROM (computer chip) from ECM prior to returning! Return core in the box you receive. Full core credit will be issued for rebuildable core only! Non-rebuildable cores will not receive credit. Send cores prepaid to: Eckler's, 5225 S. Washington Ave., Titusville, FL 32780. A Photocopy of your invoice must be included. Core must be returned in the original box for full credit.
Item# 38959
In Stock
$109.99 ea.
Regards, Nicholas
To Ecm
