Hurst Shifter
Old Mar 20, 2006 | 09:13 AM
96vetteLT4's Avatar
96vetteLT4
Default Hurst Shifter
Anyone installed one of these on their C4. Mines a 96 LT4 and I hear conflicting stories on the install. Some say you have no chance getting the pin out that holds the shifter on without droping the exhaust and maybe the trans. Some say that if you loose or break anything you are toast? Some say neither has to be done. Anyone give me some details on the real install. I've already looked at Hurst PDF install instructions which are a waste. Thanx......G
Old Mar 20, 2006 | 09:29 AM
mothersworry's Avatar
mothersworry
The installation is a PITA. I would say get the car as high as you can, drop the exhaust to gain additional working room and have fun with removing and installing the pin. I am lucky, I changed mine with the trans out of the car.
Old Mar 20, 2006 | 09:46 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I did mine, it sucked but its certainly not impossible.
Old Mar 20, 2006 | 11:06 AM
STL94LT1's Avatar
STL94LT1
I installed my Hurst without dropping the exhaust. But, it was a PITA.
Old Mar 20, 2006 | 12:23 PM
MYCoupe's Avatar
MYCoupe
Well I did mine w/o the exhaust in the way and it was still a pain. If you can get the car on a lift then you can probably get away w/o removing the exhaust.
Old Mar 20, 2006 | 12:46 PM
Toy90's Avatar
Toy90
I have a 94 and I didn't think it was hard with the exhaust at all. I spent maybe 15 min under the car total. If you have a long punch that drops below the exhaust so you can hold onto it there isn't much in the way. I'm wondering if maybe my exhaust wasn't quite centered which may have helped. I know my clutch was changed before I got the car which also may have helped the pin to come out. All I did was unplug the VSS sensor and push the pin clip out of the way with two screwdrivers and drive the pin up.
Old Mar 20, 2006 | 01:48 PM
TM-Z06's Avatar
TM-Z06
My hands and forearms are too big, so I had to remove the exhaust. If you have an aftermarket exhaust, then it's not that bad. I only had to remove the inlet pipe(s) to the resonator.....not the entire exhaust.
Old Mar 20, 2006 | 02:09 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
The worst part for me was keeping the rubber boot out of the way while trying to get that pin in.
Old Mar 20, 2006 | 05:32 PM
427t-top's Avatar
427t-top
is it worth the trouble?
Old Mar 20, 2006 | 08:37 PM
EvanD's Avatar
EvanD
CF Community Team
I did it on jack stands and dindn't drop the exhaust or tranny. It was very easy except getting the rubber boot back onto the back of the tranny, still haven't gotten back under it to get it on all the way. The only problem with the install was the big pin was a little too short to get the clips on. I ground a little of the housing to give it a little extra room. It was deffinitely worth the effort. Not having the reverse lock out is great!!
Old Mar 20, 2006 | 08:56 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old Mar 20, 2006 | 08:57 PM
Mr Mojo's Avatar
Mr Mojo
Old Mar 20, 2006 | 08:58 PM
Mr Mojo's Avatar
Mr Mojo
We did four in one day at Rex Ruby's house and we removed the exhaust on all four cars. Main reason was if we would have had to do it, it was already done, so it saves time to just remove it, it isn't that hard unless it's the first time you're removing the exhaust.
I wish we would have took pics that day.
To Hurst Shifter
