Pre-95 Optispark GM Conversion Kit
Old Aug 15, 2001 | 10:26 AM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default Pre-95 Optispark GM Conversion Kit
Would someone please list the part number and price for the pre-95 optispark conversion kit sold by GM. I just bought a 94 optispark and would like to apply the fix before installing it on the car.
I am not interested in the CF conversion procedure or the Mid America solution.
Thanks!
Old Aug 15, 2001 | 11:19 AM
R23HTC's Avatar
R23HTC
Default Re: Pre-95 Optispark GM Conversion Kit (mshipon)
I would like to know more about this also, as when the engine is rebuilt I'd like to put any possible opti-crap problems to rest.
Old Aug 15, 2001 | 11:45 AM
18carfan's Avatar
18carfan
Cruise-In II Veteran
Martin,
I'm not aware of a "GM" kit. The only other way to convert one besides the CF or MA procedure is to buy all the parts necessary to install a '95-'96 opti. This would include the front cover, camshaft, and timing components from a '95-'96 and obviously a lot more work. The CF procedure seems to be fairly easy and inexpensive. The GM vacuum harness they use (12558921 - which is the new P/N) is only $8.47. Unless there's something out there I haven't seen yet, that's the only options I'm aware of. -Jeff
[Modified by 18carfan, 9:57 AM 8/15/2001]
Old Aug 15, 2001 | 11:49 AM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default Re: Pre-95 Optispark GM Conversion Kit (18carfan)
Thanks Jeff... that really helps to clear up some of the conflicting information I've gotten.
Old Aug 15, 2001 | 12:56 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Since you have a 94, are you talking about the moisture eliminator kit for opti's made before 95?
Old Aug 15, 2001 | 01:06 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Pre-95 Optispark GM Conversion Kit (BrianCunningham)
Dag, Brian Cunningham! Off topic, I know, but you did it to me again. Scrolling along minding my own biz' when I see your sig column and the C-O-L-D-E-S-T C4 rims on the Forum! :cool:
Old Aug 15, 2001 | 01:14 PM
BrianCunningham
Default Re: Pre-95 Optispark GM Conversion Kit (onedef92)
Thanks :D
Why don't you get a set?
Old Aug 15, 2001 | 01:37 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Hey Brian... Yes, that's what I was referring to, but according to Jeff, GM doesn't make such a conversion for a 94 OptiSpark.
Old Aug 15, 2001 | 01:55 PM
BrianCunningham
look in tech/tips
You can get the kit ( not GM ) through suppliers, Mid America????
Old Aug 15, 2001 | 08:16 PM
moffitt's Avatar
moffitt
I used the 95 vacuum harness on my 94 (a GM part), It was recomended in the article by in Corvette Fever. I can't seem to find the magazine at the moment!
[Modified by moffitt, 6:17 PM 8/15/2001]
Old Aug 15, 2001 | 11:22 PM
Ramrod92's Avatar
Ramrod92
Here it is, could take a while to load on 56ks. http://gab328.tripod.com/Car_mechani.../opti_fix.html :crazy:
To Pre-95 Optispark GM Conversion Kit
