Superram base, difference vs stock
Old Mar 21, 2006 | 05:43 AM
Sliding's Avatar
Sliding
Default Superram base, difference vs stock
There is a passage in the Accel base that goes to cooling passage
which doesn't exist on stock base.
Should I just plug that hole?
Old Mar 21, 2006 | 07:14 AM
adi4's Avatar
adi4
Yes you can just plug that hole, its in there for the temp sender for the 9th injector ( cold start injector ) found on some of the earlier vettes
Old Mar 21, 2006 | 08:03 AM
Runum's Avatar
Runum
He's right, you can plug it. I used it for the location to put the sensor for my lower temp fan switch. Good luck.
Greg
Old Mar 21, 2006 | 10:09 AM
Sliding's Avatar
Sliding
O.K. Thanks.
Old Mar 21, 2006 | 10:32 AM
Eike's Avatar
Eike
Does anybody know the thread of this hole?
I want to put a temp switch for an additional fan there and need to make an adaptor ...
Old Mar 21, 2006 | 10:59 AM
conv90's Avatar
conv90
Sorry Sliding if I hijack this thread but I have question.
I have a Superram. mine is a 90
I haven't (it's a 90...) a cold start inj.
I know that peaolple with 88 and earlier have to PLUG a hole in the fuel rail. To make the story short all people with an 88 or earlier have to delete the 9th injector...Right?
Reading a tech article in the Vader's site I read this advise:
12. On applications where the cold start solenoid is not used, a block off plug and plate with an O-ring is supplied. This should be installed in the machined hole in the drivers side runner and held in with a runner bolt. "
My question: In this advice we are not speaking of the hole in the front PASENGER side of the intake manifold (the hole of the Sliding question..) AND we are NOT also speaking of the hole to plug for the people with the 9th injector that have to plug a hole in the FUEL RAIL.
Here we are speaking of a hole in the DRIVER side of the RUNNER.
Could someone clarify this?
And what happens if this hole is NOT plugged in a factory car WITHOUT the CSI as mine?
THANKS
Here the complete article:
http://temp.corvetteforum.net/c4/vader86/superram.html
-Beppe-
Old Mar 21, 2006 | 01:21 PM
Morley's Avatar
Morley
Its either 3/8" or 1/2" NPT...Sorry I can't remember which exactly it is. I just got a brass plug from Home Depot and put it in with Permatex PST thread sealant.
Old Mar 21, 2006 | 01:30 PM
Morley's Avatar
Morley
THANKS
-Beppe-
I believe the runners are of a universal design, they come with the hole for the CSI. If you don't have/use the CSI you need to use the block off plug he mentions or you'll have a HUGE vacuum leak.
Old Mar 21, 2006 | 10:03 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm absolutely positive it's smaller than 1/2" NPT. So I guess that it must be 3/8". The coolant nipple is 1/2NPT.
Old Mar 23, 2006 | 05:29 AM
conv90's Avatar
conv90
Is this plug located at the base of the driver side runner?
Is it held in place betwen the intake manifold and the runner?
Thanks.
COuld someone post a pic of this block?
Thanks again.
.Beppe.
Old Mar 23, 2006 | 09:48 AM
vader86's Avatar
vader86
are you talking about this?
Old Mar 23, 2006 | 10:17 AM
conv90's Avatar
conv90
I think yes....
I haven't the 9th inj in my 90. 88 and earlier yes.
The instructios says (for pieple like me with a 90-91) to use a "plug" between the Driver side runner and the base manifold.
..I haven't this plug and i don't knw where find it.
Read also the Morley reply to understand what Im speaking for..
-Beppe-
-edit-
to clarify:
"" On applications where the cold start solenoid is not used, a block off plug and plate with an O-ring is supplied. This should be installed in the machined hole in the drivers side runner and held in with a runner bolt. ""
Old Mar 23, 2006 | 01:47 PM
tequilaboy's Avatar
tequilaboy
I just bought a cold start plug from The Detail Zone for $8.
www.thedetailzone.com there are other sources as well if you run a search.
Even though I now have the plug, I am half-tempted to just use some Fasteel (steel reinforced epoxy) to make a plug to fill and bond to the hole in the runner. If I ever want to go back to the CSI, this maybe a problem to remove...
On a related note: I have already used some Faststeel on one of my SR runners to build up the gasket sealing surface about 1/8" in the vicinity of the egr ports where the gasket slots tend to be cut too close to the edge of the flange. I have the good gasket with the corrected straight slot length 3/4", but the other one is borderline.
I guess I'll try the plug that I have first and see if it leaks. I will probably also use some yamabond4 for sealant.
Old Mar 23, 2006 | 03:05 PM
Sliding's Avatar
Sliding
I don't have that hole on my runners.
Old Mar 23, 2006 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I think yes....
-Beppe-
-edit-
to clarify:
I ordered the wrong part and ended up with the plug (wanted the plug for fuel rail) you are looking for. Let me know if you need it.
Old Mar 23, 2006 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Mine is holeless too It seems that they made a version of runners for with CSI and without CSI
Old Mar 23, 2006 | 08:17 PM
vader86's Avatar
vader86
I believe what they are selling now is blocked off already.
To Superram base, difference vs stock
