LT1 option POLL?
Old Mar 21, 2006 | 09:02 AM
aboatguy's Avatar
aboatguy
Default LT1 option POLL?
What would be your choice?
Old Mar 21, 2006 | 09:06 AM
81c3's Avatar
81c3
Old Mar 21, 2006 | 09:12 AM
aboatguy's Avatar
aboatguy
Originally Posted by 81c3
I am leaning towards a 396, check the poll at the top.
Old Mar 21, 2006 | 09:14 AM
81c3's Avatar
81c3
Ahh, now the poll is there....it wasnt before
I went 350. Its versatile as heck & just plain dependable.
Old Mar 21, 2006 | 09:57 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Is money a no factor?
Old Mar 21, 2006 | 10:00 AM
RFDrpm's Avatar
RFDrpm
I would do the 383. Its just plain easier. All the parts are available, and lots of other people use this set up, so you can find help and ideas easier. IMHO
Old Mar 21, 2006 | 01:51 PM
neat's Avatar
neat
Lol, it's like asking-
"Hey, I am going to Europe, can you tell me where to eat?"
Well, it depends on what you like to eat, your budget, where you are going in Europe, and about a million other things.
What's the goal with the car? Ultimate power production, reliability, forced induction, etc...
What's the budget?
If it were me, and I had a huge pile of money to sink into the car, I would build a low compression 355, and pay LPE to turbocharge it. You could make 600+ RWHP and be 100% daily driver with a set-up like that.
Old Mar 21, 2006 | 02:11 PM
bobmic93's Avatar
bobmic93
You seem like your trying to get every bit of HP out of the car. A 396 will put you well into the 400rwhp range. I voted for the 396!
Old Mar 21, 2006 | 02:17 PM
LT4POWR's Avatar
LT4POWR
Old Mar 21, 2006 | 02:53 PM
RFDrpm's Avatar
RFDrpm
Originally Posted by LT4POWR
HA HA !!!
Old Mar 21, 2006 | 03:14 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
It could put you into the 400rwhp range.
I have a mild 406 that doesn't put out anything near 400 crank hp....and there were lots of 396 big blocks that were rated at 375 crank hp (gross) and less back in the day.
All that said, there is no substitute for cubic inches, especially in a street machine.
Larry
code5coupe
Old Mar 21, 2006 | 04:25 PM
bobmic93's Avatar
bobmic93
Into the 400hp range with the other mods like poted heads/cam etc. that ABOATGUY is doing to his ride.
Old Mar 21, 2006 | 05:17 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
On my 86 I just threw in a 434,might as well go all the way.
Now they have a 454 ,always more ci is the way to go.
Old Mar 21, 2006 | 05:22 PM
gixxr's Avatar
gixxr
what is that a lawnmower engine? now seriosly folks 4cyl's should only have 2 wheels
Old Mar 21, 2006 | 07:21 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I gave you more details than I've mentioned around here so far, but more details will be forthcoming here as the build nears completion. Work has begun in earnest at this point.
Old Mar 21, 2006 | 08:39 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
How about going this way?
355 with a very mild cam.. nice pistons.. Decent rods, good bolts and a vortech or procharger...
A 355 is a hole lot less expensive and can perform damn good
Alvin's Avatar
Alvin
St. Jude Donor '05
BTW.. my partners 355 caprice runs 10.90's. Thats a big car to go 10.90's on motor
To LT1 option POLL?
Old Mar 21, 2006 | 08:57 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Call me lazy but when the time comes(mabey next year) I am going this route
http://cgi.ebay.com/ebaymotors/ws/eB..._BIN_Stores_IT
383 complete installed and tuned for $5k
LT1 BLOCK:
CLEANED
CLEARANCED FOR THE LONGER STROKE
BORED +.030
CAM BEARINGS AND FREEZE PLUGS INSTALLED
LINE HONED
ASSEMBLED WITH THE FOLLOWING PARTS:
SPEED PRO SKIRT COATED HYPEREUTECTIC PISTONS - ADD $225 FOR SPEED PRO FORGED
INTERNAL BALANCED 3.75 STROKE LT1 Eagle "ESP" Crankshaft
Premium plasma moly file fit ring set
EAGLE "SIR" Forged I-Beam Connecting Rods
FEL PRO GASKETS
Clevite 77 Rod and Main Bearings
Durabond Cam Bearings
Pioneer Brass Expansion Plugs
COMP CAMS HIGH PERFORMANCE ROLLER LIFTERS
COMP CAMS HARDENED PUSHRODS
CAT ALUMINUM FULL-ROLLER ROCKER ARMS
ARP HEAD STUDS
CLOYES Timing Set
GM water pump drive
HERE ARE A FEW CAMSHAFTS TO CHOOSE FROM:
219/228@.050 .492/.492 with a 1.5 and .525/.525 with 1.6 rockers 112lsa - LT4 Hotcam Profile
218/224@.050 .495/.502 with a 1.5 and .528/.535 with 1.6 rockers
230/236@.050 .510/.520 and 544/555 110 or 112
224/224@.050 .525/.525 and .560/.560 110, 112
234/242@.050 .538/.559 and 574/596 112, 114
234/246@.050 .530/.550 and .565/.585 112
217/225@.050 .505/.530 and .539/.565 112
217/225@.050 .485/.505 and .517/.539 112
LT1 HEADS (YOUR CHOICE OF ALUMINUM OR CAST IRON..) HERE IS A LIST OF WORK DONE TO THE HEADS:
CLEANED
PORTED/POLISHED AND MATCHED TO THE INTAKE
VALVE SEATS CUT THREE ANGLES
VALVES RECONDITIONED - INTAKE VALVE UNDERCUT FOR IMPROVED FLOW
ISKY .600 LIFT VALVE SPRINGS
LT1 INTAKE
CLEANED
PORTED FOR A DUAL 58MM THROTTLE BODY
GASKET MATCHED TO THE HEADS
YOUR CHOICE OF EARLY OR LATE STYLE LT1 TIMING COVER AND CAMSHAFT
THIS ENGINE CAN BE CUSTOMIZED ANY WAY YOU WANT.
IF YOU CAN GET YOUR CAR HERE, I CAN INSTALL THIS ENGINE.
I WILL REMOVE YOUR OLD ENGINE AND INSTALL THIS ENGINE FOR YOUR OLD ENGINE AND $500. THIS INCLUDES:
2500 STALL TORQUE CONVERTER OR DUAL FRICTION CLUTCH IF IT HAS A MANUAL TRANSMISSION.
TRANSGO SHIFT KIT IF AUTOMATIC.
NEW FLUID/FILTER IF AUTOMATIC.
5.5 QTS VALVOLINE BREAK IN OIL.
2 GALLONS ANTI-FREEZE.
FULL PCM REPROGRAM
STEP BY STEP DIGITAL PICTURES
THE REMOVE / INSTALL / TUNE WILL TAKE NO MORE THAN 2 WEEKS.
Old Mar 21, 2006 | 09:02 PM
bobmic93's Avatar
bobmic93
LT1 BLOCK:
CLEANED
BORED +.030
LINE HONED
FEL PRO GASKETS
ARP HEAD STUDS
CLOYES Timing Set
GM water pump drive
CLEANED
LT1 INTAKE
CLEANED
FULL PCM REPROGRAM
That is a awesome price. I would pick the 224/224 cam with 110 LSA and youll need long tubes with that.
Old Mar 21, 2006 | 09:04 PM
bobmic93's Avatar
bobmic93
Check out STEVE40TH vette. He has 425hp 419 tq and Im pretty sure its a 396!
