My '94 has been stored for about 4 months. I took it to a local Chevy dealer to change oil and flush cooling system. After they bled the system they said they can't get the cooling fans to kick on unless they manually hit the fans with the A/C.
Any suggestions? Thanks
Yeah. They need to let it warm up more. Primary fan turn on temp is ~219*. Secondary fan turns on around 227*
Did they bleed the coolant? There are two bleed screws near the TB that don't exist on earlier cars. Maybe there's an air pocket there affecting the sensor?
Do they know WTF they are doing? Do they have a factory service manual? Did they RTFM?
Jim,
I was working on my fans today and I do believe the primary fans stay on all the time while the secondary turns on at 225...correct me if I am wrong...
I think your car is just fine. Primary comes on with A/C, or at about 225, cycles temp down to about 219. Secondary comes on about 235. Might be 239 just cant remember exactly.
Point is everybody here is on the same page. Charge on.
