crossfire to TPI ?
Old Mar 26, 2006 | 06:12 PM
pipe's Avatar
pipe
Wow! lot's of opinions here good and bad about the swap idea. I wanted to make the car into a bracket car and i'm more familiar with the Tuned Port. I allready have a 383 with a Mini Ram so I wouldn't really need much except the wiring harness and the ECM I guess. The Mini Ram sits very low so I don't think I would have much problem with the clearance issue under the hood. The reason I brought this swap up is because I probabally don't know what to do to make the Crossfire work well under drag race conditions and have heard that Crossfire's have their issues. THANKS GUYS FOR ALL THE REPLY'S Pipe
Old Mar 26, 2006 | 08:49 PM
CFI-EFI's Avatar
CFI-EFI
No issues with the Crossfire. Limitations, YES, but no issues. It runs well and is dead reliable.
RACE ON!!!
Old Mar 26, 2006 | 08:53 PM
rick lambert's Avatar
rick lambert
Isn't cross fire like an old carb setup CFI-EFI just kidding-don't unload on me.
Old Mar 27, 2006 | 04:52 AM
adi4's Avatar
adi4
Been there done it, and yes it was well worth it I did use a 1990 SD setup that I had left over from my 90 just bought a harness from jim at http://www.jimsperformance.com/carty3.html and a new ecm ( 91 F body ) and jim burnt me a prom vats disabled, the only thing is that your cons / ave fuel wont read but that is no big loss.
If you get stuck on the wiring give us a yell cos I have it writen down somewhere , the only pain in the whole conversion was doing the work under the dashboard for the wiring and finding space for the ECM, the rest was easy.
End result .... the car is much more responsive and better on fuel, and yes I would do it again tomorrow it was well worth it
Old Mar 27, 2006 | 02:24 PM
CFI-EFI's Avatar
CFI-EFI
It looks a little like dual quads on a cross ram. It must be the same thing.
That Crossfire must have been severely neglected and in need of some serious maintenance. I had intended to comment further, but adi4's signature makes all my points so much better than I ever could.
RACE ON!!!
Old Mar 27, 2006 | 03:43 PM
telboy's Avatar
telboy
5th Gear
Default Go faster info for a CFI
Hi all from the U.K.
I own an '84 CFI which I must first say runs really well and is in excellent condition in all areas.Really interesting reading these threads about CFI /TPI conversion.I agree with the fact that for the effort and money, gains are minimal.Especially here in the U.K where parts and labour costs would be much higher than in the States.
The mechanic that services my car drives loads of different Vettes in his work and says my car runs really strong,better than some later TPI's,.which is good to know!
However,you guys must know more about getting better performance from a CFI than any one here in the U.K. Any suggestions on stuff that can be done that's not too expensive?!
One problem that showed up on my car recently. It was being filmed for a TV program on restoring older C4's, and was given a good thrashing around an airfield.Mostly sideways,drifting it around bends etc. Not the way it's normaly driven on public roads.
The problem was engine cutting out when the car was really sideways,and when this happened the tires would grip,flicking the car back into a straight line,and then the engine would be on full power again. I think this is the fuel pump.Maybe on very hard cornering the fuel is pushed to the side of the fuel tank away from the pump.Would this be the pump being worn (it's probably original ) or for this sort of driving, do I need an uprated pump?
Any help on all this would be appreciated.
Old Mar 27, 2006 | 04:14 PM
adi4's Avatar
adi4
RACE ON!!!
The crossfire was running fine with no codes, and sir you are so very kind and a man of few words
Old Mar 27, 2006 | 05:09 PM
Brinitvette's Avatar
Brinitvette
Default C4 CFI to L98 (TPI)
I think its a good idea. I've got an 84 (CFI/auto) as well, cheapest of the C4... so i figured its best place to start for any sort of project or build.Frankly... even mint early c4's and even the earliest (CFI) dont seem to be woth that much. I've gone with a LT1 set up out of a wrecked 95' LT1 car. Still going to run the 700R4 till all running bugs have been ironed out. Then I'm going to swap out the 700R4 for a ZF-6speed. With the stock motor LT1, exhaust and msd... It will be a completely diffrent car than before. All I'm looking for is cheap fun.My 2
Old Mar 27, 2006 | 06:00 PM
Z06_BluByU's Avatar
Z06_BluByU
If you really want some performance dump the L83 engine and crossfire setup and slip a LSx engine in that puppy... then you'll get the ear to ear grin your searching for.......
Old Mar 27, 2006 | 08:50 PM
CFI-EFI's Avatar
CFI-EFI
There must have been something wrong with it. TPS's just aren't that much more powerful than the Crossfire. My Crossfire has a TPI or two for breakfast...even more for lunch.
RACE ON!!!
Old Mar 27, 2006 | 09:24 PM
Ramanstud's Avatar
Ramanstud
For the Crossfire guys...
Had I to do it over again, I think I'd consider going 383ci with an Xram plenum, overbored TBs, heads/cam... that would be pretty potent I think. The hard part would be tuning on a slower ECM.
The crossfires DO have a ton of potential, but... like carbs... are not for everyone. Different strokes for different folks.
Old May 22, 2006 | 09:38 AM
CAJUN C4's Avatar
CAJUN C4
Originally Posted by qws
Its not worth changing the CFI to TPI, the only gain is about 25hp at best. I've looked into prior to making mods on my car and the cost to do it with a used TPI will run about $900 or so and for what? A lousy 25hp, don't think so. It will be a lousy investment for you.
There is nothing wrong with a CFI if its tuned correctly and its pretty simple to work on as well. If you want to make mods then spend your money more wisely such as
1) port your intake- $0 and your labor
2)headers- cheap set $140.00, better set set $500
3) at least if you go with the x-ram and some rr's that gonna cost $600, and that investment is at least wiser than the TPI.
I installed rr's,headers,x-ram and I'm lovin the car.
And stay away from a carb I think and I don't have "facts" just opinion, I feet the TB's from the CFI are better and more reliable.
X-Ram is the way to go.
Old May 22, 2006 | 10:53 AM
  #33
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
I also run an 84 CFI. I love it. But I will get some restrictions out of the way in future as well. I got quite some very good info from CFI-EFI and decided to port the intake manifold, mount 1.6 RR and mount 1 5/8 hedman hedders with a better flowing Cat and mufflers. Because I live in Spain, the material transport will be a pain in the ... and has to be sorted out.
I do NOT argue that the TPI should run fine and has the potential to be upgraded, but..
I agree with the opinion that the money and effort to put into a TPI conversion is not worth it compared to a good running CFI with removed restrictions. Also the gas milage of the CFI is GOOD. I run 9 liters at a 100 kM with a speed of 140 kM/Hr. I consider that very good for an engine of this size. I have the opinion that the money spent at a TPI conversion can be spent better.
Old May 22, 2006 | 11:44 PM
  #34
anesthes's Avatar
anesthes
A used TPI setup can be had for 200-300, and you don't need a harness. Some donor connectors, and injector plugs, and about 45 minutes to repin it. Spend 15 minutes at the junkyard gathering electrical parts you need (about $5-10),
I'm not sure about hood clearance on Crossfire vettes, i'm not a vette expert, but I'd think a miniram would fit being so low profile.
I'm finding the majority of vette owners are afraid of things that are not plug and play. Or maybe I'm just reading the wrong posts.
-- Joe
Old May 22, 2006 | 11:46 PM
  #35
bogus's Avatar
bogus
that's when you use the ECU from a later pickup... 1987 or so if I remember rightly.
Old May 23, 2006 | 08:46 AM
  #36
CAJUN C4's Avatar
CAJUN C4
I have one with adapter harness if you would like to buy it.
Old May 23, 2006 | 09:11 AM
  #37
Googan's Avatar
Googan
How much are you looking to get for it?
To crossfire to TPI ?
Old May 23, 2006 | 09:22 AM
  #38
CAJUN C4's Avatar
CAJUN C4
I paid $300.00 for it 2 years ago to have Speedtronics install the prominator dip switches,harness etc..Still in box un-opened;
How's $250.00 Shipped sound.?
BTW..This does not include the $100.00 cost of the 8746 itself..
My total investment is $400.00
see www.speedtronics.net
Bill Hitchcock
Old Jun 30, 2006 | 01:23 AM
  #39
Yguy's Avatar
Yguy
Instead of a change to TPI, check these guys out,
http://www.turbocity.com/default.php?cPath=16
Old Jun 30, 2006 | 07:13 AM
  #40
Bruce Witherspoon's Avatar
Bruce Witherspoon
Originally Posted by steve1ph2
valid points. 1. there are ways to get around that depending on your resources. 2. buy a honda. 3. seems most people drive their vettes on sundays to the drive inn and back no really big elevation swing. 4. longevity? a person looking to modifi a sbc isnt worried about an extra 3k miles. 5. crisp throttle response? same with carb......at least mine. i done the holy " super ram " setup befor i upgraded to the carb same or better performance with out all the hassle. this is the good thing about this or any other forum you get the pro`s and con`s.
Sorry, I sent you a PM about intake by mistake.
