crossfire to TPI ?
RACE ON!!!
TBI injection is actually pretty reliable.
There is nothing wrong with a CFI if its tuned correctly and its pretty simple to work on as well. If you want to make mods then spend your money more wisely such as
1) port your intake- $0 and your labor
2)headers- cheap set $140.00, better set set $500
3) at least if you go with the x-ram and some rr's that gonna cost $600, and that investment is at least wiser than the TPI.
I installed rr's,headers,x-ram and I'm lovin the car.
And stay away from a carb I think and I don't have "facts" just opinion, I feet the TB's from the CFI are better and more reliable.
The CFI is a good reliable system that can be vastly improved by a DYIER.
The TPI is little, if any, improvement over the CFI. The conversion is expensive, time consuming, and offers little or no gain.
A carb conversion CAN offer a performance advantage over the CFI, but it is a step backward in technology.
Aftermarket EFI systems offer the biggest bang for the buck, if a modified Crossfire doesn't have enough BANG for your tastes. Besides the TPI alternatives Morley mentioned Holley, Edelbrock, and others, offer stand alone EFI systems.
RACE ON!!!
RACE ON!!!
RACE ON!!!
1. The ability to pass emissions if you live in an inspection area.
2. Fuel mileage.
3. Driveability in various elevations, temperatures, etc.
4. Longevity of the engine (efi systems burn cleaner, last longer)
5. Crisp throttle response.
Your best bet to improve performance is to modify your crossfire. Easier still, sell your crossfire and buy the car you really want.
2. Fuel mileage.
You won't just get 25 hp. TPI puts the fuel in directly to the head, so you get about a full second knocked off your 1/4 mile with stock tpi. If you go directly to a superram and good heads(vortec or better) with headers and decent exhaust you will be in the low 12's in the 1/4 mile, now that is about a 3 second gain.
The 84 is a great car as is but try not to meet a L98 or a LT-1 or LS1 at a stoplight, they will eat you for breakfast.
84 vettes have the best handling, and add a superram with all that torque, suddenly you are the big dog of the C4 family.
Don't forget you have to change:
fuel pump,fuel lines,computer,harness,buy tpi setup.
Your 84 vette is already speed density, so go with the later speed density TPI setup, your sensers are the same, and the bonus is that it will fit under your stock hood because you don't need a mass air flow sensor, just put a cone air filter on your 58mm throttle body. The superram is smaller than the stock air cleaner box on the 84, and your ducted work will put cool air to the top of your engine.
WORDS TO LIVE BY:
A VETTE LOOKS FAST SO MAKE IT FAST.
A VETTE LOOKS FAST SO MAKE IT FAST.[/QUOTE] how true. my dad told me the car looks fast standing still and iv tried many dollars later to make it so. i wish i had the money to buy 400+ hp off the show room floor.
fuel pump,fuel lines,computer,harness,buy tpi setup..
I'm searching for a site that I read about 6 months ago about a guy that did this convesion. He had a real nice page with a lot of info. I then spoke to him directly and he did tell me that he would never do it again. Once I find it I will post it
TPI setup (preferrably no cold-start injector provisions)
1989 year engine harness w/out the cold start injector
(the MAF sensor is a plus IMHO)
braided fuel lines to go from the chassis to the intake (~4 feet)
TPI style waterneck, hose, etc
85+ style Fuel pump
and a K&N cone filter that I stuck onto the MAF sensor, and then connected to the throttle body with ducting that I made - it all fits under the stock hood inbetween the radiator shroud and the Intake. However, a typical cone filter stuck solely on the throttle body will NOT fit - there has to be some ductwork to allow the filter to hang down a little.
Contrary to popular belief: the 84 hood is more tapered in the front over the radiator than later years, so the air filter assemblies used in TPI cars will NOT fit. There are ways to get around this as I previously mentioned, but there is no signifigant clearance issue with a TPI and the hood.
Things I would do differently:
Skip the stock TPI and step up to a SuperRam intake (arguably the best intake for your automatic vette). I would also consider avoiding the OEM wiring harness and ECM, and going for a stand-alone controlled from Holly, Accel, etc since without a custom harness it equates to the same deal: engine management ONLY (and you lose certain functions on the digital dash like MPG readouts, etc).
Previous posts were right - you can get a lot of power out of the CFI crossfire system, but it's more outdated and there are fewer mods/resources available to work with (Yahoo search: crossfire injection forum). I knew where I was going and plan on eventually doing forced induction - much easier and more "bolt on" with a TPI style intake system. There are plenty of little things that I've done in tandem with this conversion, but the highlights I've tried to list here. Feel free to PM me questions.
