do you have pics of the tips u used to port them? i cant find a sand paper paddle wheel anywere...i want to get down in the tubes and open them up a lil on my slps....what did you use to get them that smooth....sure looks good!!
i'll take some pics of the stuff i used tomorrow. hopefully somebody can post them for me. most of the stuff can be purchased on line through Mcmaster Carr.
MSC industrial supply sells some nice carbide bits from the smallest to a 5/8x1".
A cut above distrubuting carries a decent selection also. Good place for cartridge rolls and flap wheels.
Dont have links but sure they will show up of you Google them.
By the way I recieved the wire harness and other parts, haven't installed them yet but the look good, thanks to you my 84 vette will have over 400 hp in the near future.
good luck with the build and installation of the harness
yeah all i used was a dremel and a few tips....took a while but it worked..oh also a drill with a rough cutting bit to get a lot of aluminum out faster. i just got a used 60grit flapper wheel from a friend and i used it on this one side of the pics i took. thats how i got it so nice and clean lookin. it worked good but the wheel is ablout out...i need to find more but i have had no luck in town findin any. i was thinkin if a got like 10 or so and a extenstion i might be able to get them down in there more...but i think i would go through them fast that way.....anyone else have any ideas? if i could find an flexable ext to get down in there that would be cool but not sure if it would work to well
Goodson Tools is a great resource for honing tools. The ball hones work great. It makes the job less tedious and you get professional looking results. Additionally the ball shape keeps the ports round and not deformed (which is easy to have happen when doing it freehand). I did a killer job on my super ram with the hone *****.
Nice links, would the ball hone actually remove a measurable amount of metal or just give a "finish" to it?
I was able to remove all of the rough casting plus more with the ball hone. The ball hones come in different grits, so I started out with a course ball and then did a final smooth with a finer ball. I kept tabs on the runner sizes with a digital caliper. All that you need is a power-drill and some cutting lube.
