Elim. Air Pump
Old Mar 26, 2006 | 10:01 PM
Biff Buyer's Avatar
Biff Buyer
Default Elim. Air Pump
just dropped the rebuilt engine back in today, WOOT . Anyways im getting rid of practically all of my emmisions stuff, that means getting rid of the air pump. The replacement pully is too much. I'd rather just leave it on there instead of paying i think $130 for a dummy pully. Can i just get a shorter belt? will i need to change the belt path? i would just try to figure this out myself, but im sure somone has done it and i dont have any of the front part of my engine back on yet. Thanks
Matt
Old Mar 26, 2006 | 10:05 PM
chucks88's Avatar
chucks88
My feeling is half the appeal of the delete kit is how it cleans up the engine. Someone out there in C4 land may have one kickin around. Try posting a thread in C4 parts for sale as you might be able to pick one up for a song.
Old Mar 26, 2006 | 10:14 PM
redrose's Avatar
redrose
you can't just use a shorter belt
but i relocated my alternator to where the air pump was (had to fab a couple flat brackets from alum plate) aaaaannnnndddd used a shorter belt (93 chev van v6 no air, i think-its writen on a note out in the car--i'll check if u need it)
Old Mar 26, 2006 | 10:45 PM
vader86's Avatar
vader86
I wasnt able to find a shorter belt that would work.
Old Mar 26, 2006 | 11:14 PM
Demonic85's Avatar
Demonic85
Yeah I find the A.I.R. pump pretty annoying. By deleting it what do you gain? I mean if you just replace it with a dummy pulley it will still have the same amount of drag unless its a performance pulley, in which case I could understand why it would be an expensive kit.
Old Mar 27, 2006 | 12:05 AM
86PACER's Avatar
86PACER
If it's because of noise, you can gut it for free.
Old Mar 27, 2006 | 12:07 AM
86PACER's Avatar
86PACER
Not much. Cleans ups the enigine bay more than anything. I could not justify the cost of the eliminator pulley. I just gutted mine. It's just there spinning doing nothing. No more noise.
Old Mar 27, 2006 | 12:49 AM
vader86's Avatar
vader86
Nothing. Just a loss of some pounds on the front end.
It wont give you any power gain, as the pulley on the AIR spins pretty freely.
Old Mar 27, 2006 | 09:05 AM
redrose's Avatar
redrose
relocating the alternator up to where the air pump was puts the alternator in a higher air flow area and allows more air alongside the motor...with the alternator up there is no need for any new pulley
you can get a good guess at what your ''re-engineered'' belt length needs to be by running your yo-yo (steel measuring tape) around the belt path ...go to the parts store and belt part numbers indicate length and number of grooves--tell the parts guy you're brewing something and will need to exchange a couple times to get it right cause you will (never had the parts guy say no to me)
Old Mar 27, 2006 | 11:18 AM
Davemc1963-87conv's Avatar
Davemc1963-87conv
REDROSE,
Do you have any pictures of your mod? I would find this very interesting to see. Also the actual belt length you used (that you said you might have) would be good too.
Dave
Old Mar 27, 2006 | 11:35 AM
redrose's Avatar
redrose
i've got a $20 digital camera and would be glad to post--just tell me where to go (to find out how to post em)
belt i've got on now is a napa 25-060780...i think the ''06'' means 6 groove, and 0780 means 78 inches long (seems like the right length--old age,the mind is second to go)...i'm using the cs-130 alt now cause it look better--i had a cs140 on earlier and that needed a belt 1 inch longer because brackets were higher to clear the rocker cover
Old Mar 27, 2006 | 04:18 PM
Davemc1963-87conv
redrose,
Posting pictures is something I have never done...yet. I have only just moved into the digital camera age myself and have difficulty viewing pictures on my PC never mind posting them on a forum. Unfortunately it looks like you have as much idea on the subject as I do (none).
Anybody help out on this one?
Dave
Just looked in the FAQ section and there are some instructions on attachments, I don't know if that would work or not??
Old Mar 27, 2006 | 06:20 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
FYI-- I read some place (here) the "84" is the only vette that can use a shorter belt w/ pump off. I'll find out this summer
Old Mar 27, 2006 | 08:26 PM
Bubba91's Avatar
Bubba91
undefined
How does the car adjust to not having an operational air pump?
Will it run worse without it?
Old Mar 27, 2006 | 09:04 PM
RICEKILA's Avatar
RICEKILA
From what I can remember reading -- motor looks better, less parasitic loss ( 1-2 more HP maby more) , one less thing to brake and squeal,and a few other reasons ( I don't like the looks of it eather) do a search--I did
PS Edit-- and some thing about closed and/or open loop?
2ed.PS Edit-- also takes 5lbs.(?) off front end.
Old Mar 27, 2006 | 09:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If your handy, you can make your own. Here's some info on one i put together. All measurements were taken from my 86, but should still work for your year.
http://members.shaw.ca/dankai/Air%20...Delete%20Info/
Old Mar 27, 2006 | 10:04 PM
vader86's Avatar
vader86
Car doesnt care if its there or not. AIR's only purpose is to get the cats lit quicker, emissions only.
Old Mar 28, 2006 | 08:21 AM
redrose's Avatar
redrose
and don't feel guilty about "wrecking the environment"--96 impala lt1 were such a gm headache with a.i.r. pump that gm has a federally approved ''field delete'' of the a.i.r....proves how much it must really be worth
To Elim. Air Pump
