TPIS or Hooker Headers???
Old Mar 27, 2006 | 10:50 PM
rssshen vette's Avatar
rssshen vette
Default TPIS or Hooker Headers???
I'm about to buy a set of headers. I'm not sure which one to go with TPIS or Hooker. The Hooker is a little cheaper than TPIS. Is Hooker worth it?? Is there anyone in the Forum that has used hooker headers. If so was it worth the price? Jegs part # 520-2149
Rsshen vette
Old Mar 27, 2006 | 11:05 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
The sticker on my back glass says it all!!
Just make sure you order them ceramic coated.
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
I had a lot of trouble getting the Hookers to fit the first time I installed them. A LOT of trouble. However, once they heat cycle enough times they will be easier to reinstall if you ever need to. If I were to do it over again, I would probably spend the extra for the TPIS.
Old Mar 27, 2006 | 11:08 PM
bacardioil's Avatar
bacardioil
all headers are not made equal. if your going to spend hard earned money on headers, buy headers that give you the real performance that your looking for. EMs racing headers. they will be money well spent. if moneys a problem save up the difference and you wont be sorry. when it comes to headers you get what you pay for.
regards
Old Mar 27, 2006 | 11:12 PM
Zix's Avatar
Zix
regards
Hookers are a bit cheaper so if money is a concern go with them, but the TPIS and EM headers are almost identicle in price and the EM headers are a much better set.
Old Mar 27, 2006 | 11:13 PM
pipe's Avatar
pipe
I have a set of Hooker #2150s no air pipes and only had minor fitment issues not major. But their ceramic coating has alot to be desired. Mine have only been on about a year and allready the coating is flaking off. The TPIS headers use the stock exhaust bolts and also have the standoff tubing to re mount the alternator brace and air conditioner brace. Both are good headers. GOOD LUCK WHICHEVER YOU CHOOSE Pipe
Old Mar 27, 2006 | 11:17 PM
vader86's Avatar
vader86
TPiS is better in fitment, and allows reuse of stock bolts and braces (which are important).
Old Mar 28, 2006 | 01:42 AM
skateparkdave
I've heard this but either they made an improvement or I'm lucky. Mine are a year and a half or so old and still look like this.
I had ZERO fitment issues other than the need to fab the Alt. brace thing.
Old Mar 28, 2006 | 06:49 AM
88BlackZ-51's Avatar
88BlackZ-51
I agree. Mine are 2 years old, and looks brand NEW!! Well even in 2 years. Prob only 8000 miles on them.
Old Mar 28, 2006 | 08:22 AM
JackDidley's Avatar
JackDidley
The only problems I had with TPIS were, 1- the Y pipe is not year specific, so it may need to be modified to fit your car. 2- They will lie to you and say they are in stock when it really takes 2 weeks to get them. I really do like the ability to use stock brackets and bolts (some grinding required on a couple heads) and the coating is still looking good after morethan a year on a DD.
Old Mar 28, 2006 | 08:52 AM
jan-erik's Avatar
jan-erik
Hi.
I have TPIS headers . They were easy to fit. It was only two things that had to be "adjusted. One was the support for the alternator. I had to grind off one millimeter so that it cleared the primary tube on the header. Very easy with a file or grinder. Two was a bolt that was too broad so that the wrench did not enter. I changed it to a torxbolt and everything was ok.
I have an 85 with stock cast iron heads. Change of sparkplugs is easier than with stock manifolds. No obstruction with starter.
I have the coated ones and they look as the picture above after two years. The temp. in the engine room is good. people react on lhe low temp having headers.
I live in Norway and the delivery from TPIS was fast . I ordered it and one and a half week later they had arrived in Norway.
No problems with the Y tube if following installation instructions from TPIS. Look at their site.
Good luck
Old Mar 28, 2006 | 09:48 AM
GeosFun's Avatar
GeosFun
Must be the luck of the draw. I ordered mine about 6-months ago and they shipped immediately. The muffler shop that installed them was complimentary about the fit and installation.
Old Mar 28, 2006 | 11:10 AM
Corvette0096's Avatar
Corvette0096
I have the hookers and have installed Tpis's. I would go with the TPIS. The bolts are easy to get to. There's a few things that you have to do to the hookers before you mount them. Reverse the motor mount bolts. custom wrench for that rear bolt on #8.
Old Mar 28, 2006 | 03:46 PM
GRX's Avatar
GRX
Thats why my pair should be arriving any day now! I went with them because of fit. No one has been making headers for these cars longer than tpis.
Old Mar 28, 2006 | 04:02 PM
C4driver99's Avatar
C4driver99
Go with Hooker ceramic coat is a must. Stay away from hedman
Old Mar 28, 2006 | 05:32 PM
comp's Avatar
comp
Old Mar 28, 2006 | 06:07 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
TPIS and Hooker headers are about the only C4 headers that I have not handled and examined. But I have had other Hookers and always found them lacking, some were a pathetic joke. From all reports I've read here, the TPIS headers are probably the easiest for plug changes as well as for the simpler related installation details already stated here. The TPIS also have 3/8" flanges, the Hookers only 5/16". If you can swing them, they'd be my recommedation between these two choices.
To TPIS or Hooker Headers???
Old Mar 28, 2006 | 06:12 PM
blown87's Avatar
blown87
GA Events Coordinator
I thought you were a Stainless Works man.
Old Mar 28, 2006 | 06:19 PM
LD85's Avatar
LD85
I bought Hookers and ended up cutting two pipes out and welding in two new pipes to allow for more clearance on my AFR 210's,
The pipes were # 5 and # 4 that had close plug wires, but some of this is the result of the AFR's having poopy clearance
Or I would buy uncoated hookers, cut and re-weld them, then have them coated or maybe I would go TPIS next time.
Old Mar 28, 2006 | 06:21 PM
Corvette Kid
I am. I was just responding to the two choices that the original poster was considering. I waited a long time for my SWs, I love them!
