So what will be the effect on my engine if I just cut out the cats in the stock exhaust and replace em with straight pipes? I'm running a ZZ4 with a stock exhaust - I assuming I can do better!
I would not just gut the cat... the L98 exhaust is so restrictive.
Consider this:
1) remove the exhaust from the manifolds back.
2) install a custom exhaust, more like the LT1 style, with a pair of bullet cats located about where the old pup cats used to be.
3) x-pipe
4) mufflers.
This can be modified to accept headers at any time. This type of update is worth, I would guess, about 30-40 hp. and will still pass any sniff test, and won't smell of raw fuel.
well guys - i do live in california - but i just 'sold" the car to my brother who lives in Michigan - we actually share the car -- really!
So all of a sudden - no need to worry about cal smog. The air pump is gone - along with the tubes that seemed to be recirculating exhaust back into the cylinders.
carl Johansson
actually, you do.
you don't have to pass a test, but if CARB sets up the highway testers, they can nail an outta state car... especially if it has been in CA beyond the DMVs threshold.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I don't think GM left that much on the table. I don't see what's so bad about a dual 2.5 to 3 to dual 2.25 system on a motor that only revs to 4800, except maybe the cat.
The LT1 exhaust has about 35% more cross sectional area, and revs about 30% higher.
I do. I have heard more and more often of folks with otherwise stock L98s getting nice performance gains from a better exhaust system.
Removing the stock L98 exhaust and replacing it with a 2.5-3-2.5 exh, carsound pre/main cats and aftermarket muffs netted me about .2 and 3 mph in the 1/4 mile. Results are muddled just a tad as my 60 ft varied by just under a tenth on before/after runs. MPH on each was a solid 3 mph diff.
In theory - you're probably right Andy, but in the 28 years I've lived in Central California I've never seen a CARB unit. I assume that must be a new attempt at pollution control - but I can't imagine that they would be pulling over out of state cars and checking them for exhaust. As for the threshhold - how would they know how long it has been in the state - unless they come by and check every week!
regardless - so I pull of the stock pipes where they join up to the manifolds - correct ?- then not worrying about cats - I would take 2 pipes back to an X pipe - then continue to the rear where I would run em through some elcheapo muffler - is that correct?
but you are missing the point... if you are caught in CA without cats, you are violating a federal law, which CARB enforces. You will get a ticket. And a loud car will attract that kinda attention you don't want.
The mobile units use some kinda infrared to scan the air for high concentrations. If it finds a problem, in theory at least, they issue tickets to all vehicles in that pack, via photo radar, requiring them to go in for a sniff test.
The otherside of this is the noise... the last thing anyone wants is greater attention drawn by the local LEO. And with so many towns passing tighter and tighter noise restrictions, tickets are a way of life. Why expose yourself to them?
Then comes my selfishness... I like my air to not smell like raw exhaust gases.
Roadside testing, I can't wait to see this disaster. And you thought the redlight camera lawsuits were bad...
So tell me what happens when a perfectly clean car shifts right at the sensor and spits out those unburnt HCs. Honestly where the hell would you put one anyways? In the road surface? On curbs?
They'd be better of hooking all the cars onboards to the carb communist air resources board home office so they can issue tickets everytime the ecm detects a misfire.
I know what you mean.... and I ain't a fan of it either... but it's coming.
It looks like LA and SF Bay area are the target areas.
