How much hp??????
Old Apr 2, 2006 | 11:56 AM
C4driver99's Avatar
C4driver99
Default How much hp??????
I got a 86 auto 112,000 miles on it, This summer once i can save up some $$$ I want to do some heavy mods. Rightnow ive got headers, flowmasters, true dual, no cats, air silencer removed, ect. most of the free/cheap stuff. LOL. Ok I plan on doing aluminum heads, cam, pistions and rods, rings, having the motor bored. Right now im pushing 380 or so at crank. Dont know all what has been done to the car. How much would I be expecting with all these mods done. Id really like to reach 500 on my L-98 Ive thought about upgrading to a twin turbo??? Worthwhile, possible??? hp effects?
Old Apr 2, 2006 | 11:59 AM
C4driver99's Avatar
C4driver99
BTW I am getting the rear gears changed, MSD IGNITION
Old Apr 2, 2006 | 12:13 PM
RRT vette's Avatar
RRT vette
Yeah, it should. Also add a 100-150 shot of NO2 with the forged pistons
Old Apr 2, 2006 | 12:16 PM
bjankuski's Avatar
bjankuski
If you only have the mods that are listed in your post you are not pushing 380 HP at the crank, I would estimate 260 HP at the crank.
To get 500 HP you will need to do a lot of work. In my sig I have the parts listed that gave me 500 HP at the crank.
Old Apr 2, 2006 | 12:24 PM
kpforce1's Avatar
kpforce1
if you want 500 at the crank on a N/A motor the stock TPI system has to go... and get a stealth ram, mini ram II, Superram, etc... You'd need a pretty decent cam with alot of duration and ~.600" lift or better. Heads will need at least 2.02"/1.6" (larger on the intake if possible). Heads also need to flow really well. I'd go with a 383 or better as well. Internals would be forged as well.
Now, I'd rather go FI if i was wanting 500+ out of a gen I chevy so I could have better drivability as well as more power under the curve and in a daily driver RPM range. For the TT setup, check this thread out...
http://forums.corvetteforum.com/show....php?t=1265554
A forged motor is a given with FI. Good luck in what ever you do!
Old Apr 2, 2006 | 12:41 PM
vader86's Avatar
vader86
How do you know you have 380chp?
what is an air silencer?
Old Apr 2, 2006 | 12:52 PM
C4driver99's Avatar
C4driver99
my buddy had it dynoed The previous owner mustve had some **** done to it i guess or the guy did not know how to operate the dyno which wouldnt surprise me. Ok great tips guess the L-98 is going bye bye Wasnt what i was looking for but i guess its something to work towards. BTW the air silencer is like a plastic bar that splits the air coming in at hte front of the radiator in all cars. Breaks the force down to keep it quieter. It takes like TOPS 3 horsepower but still horsepower adds up so its just two bolts and 5 minute uninstallation and i was bored again thanks everyone
Old Apr 2, 2006 | 12:55 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cubic inches, my friend-As many as you can afford.
Old Apr 2, 2006 | 01:03 PM
vader86's Avatar
vader86
WTF are you talking about, that bar isnt there to silence anything.
Old Apr 2, 2006 | 01:07 PM
RRT vette's Avatar
RRT vette
air silencer? Never have seen that!
Old Apr 2, 2006 | 02:25 PM
C4driver99's Avatar
C4driver99
ill post a pic damn vader chill out
Old Apr 2, 2006 | 02:38 PM
500hp's Avatar
500hp
This is a pretty straight forward list for 525 HP (NA), but it is not going to be cheap.
383 with 6" rods and 11:1 compression
AFR or TFS 195 heads with .600" springs and 7/16 studs
Mini Ram intake with 58mm TB
TPIS ZZX cam with 1.6 rockers
Full length 1.75" coated headers
Aggressively tuned chip w/30 lb injectors
The heads might need a little bowl cleanup and some portmatching.
500 HP might be done with a 350 with more compression, 210 AFRs, bigger solid roller cam, and tuned for 7,000 RPM.
Old Apr 2, 2006 | 02:48 PM
RRT vette's Avatar
RRT vette
Old Apr 2, 2006 | 03:00 PM
hippy's Avatar
hippy
Yea vader, the n00b told you to chill.
I dunno, a set of headers on a 235hp L98 might add 145hp? Ya never know.
Old Apr 2, 2006 | 03:06 PM
RRT vette's Avatar
RRT vette
Yeah hippy, I have heard that a racing stripe and a wing will add at least 80hp. Just joking around.
To How much hp??????
