Vette will not run
Old Apr 2, 2006 | 01:56 PM
Demonic85's Avatar
Demonic85
Default Vette will not run
I need help, my Vette will start but wont run. All I did was change the valve cover gaskets. I've checked everything: spark plugs, wires, vacuum lines. Its getting everything it needs, so why wont it stay running???
Old Apr 2, 2006 | 02:00 PM
Morley's Avatar
Morley
If it ran before you did the valvecover gasket change, then it has to be something you disturbed.
Will it run if you keep giving it gas?
Old Apr 2, 2006 | 02:03 PM
Demonic85's Avatar
Demonic85
yes it will keep running until i let off the gas, but it backfires and misses horribly while giving it gas.
Old Apr 2, 2006 | 02:06 PM
RRT vette's Avatar
RRT vette
Are there any codes showing up? Did you happen to disconnect the EST?
Old Apr 2, 2006 | 02:08 PM
Demonic85's Avatar
Demonic85
I reconnected everything that I disconnected. I checked all the spark plug wires to make sure they're in the right places. I dont know what an EST is. I dont know exactly how to check codes.
Old Apr 2, 2006 | 02:18 PM
RRT vette's Avatar
RRT vette
The EST is the Electronic Spark Timing, the ecm sets a defalt for the distrubitor if this is disconnected. This wire is located between the brake booster and distrubitor and it is a single wire (tan w/ black). It will set a code 42. Turn the key to the on position and see if the check engine light stays on. Use a U shaped paperclip and insert in terminal A and B on the ALCL under the drivers dash. The two terminals on the upper right hand corner. The check engine light should blink "one flash" pause then "two flashes" and it repeats 3 times, then the next set of flashes is the code.
Old Apr 2, 2006 | 02:38 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Checked injector connectors too
Old Apr 2, 2006 | 02:40 PM
qws's Avatar
qws
Did you knock off any sensor wires?
When I did my valve covers gaskets I disturbed the fuel pump relay connection. It looked connected but then I push on it a little and what do you know it went on a bit further then started right up
Old Apr 2, 2006 | 02:44 PM
RRT vette's Avatar
RRT vette
If you loosened any injector connections this would make it run as you described. If you didn't disconnect the battery before hand, you might have shorted a wire and blown a fuse. I would visually check these and might even test light both sides on the fuse. Just a hint.
Old Apr 2, 2006 | 09:35 PM
Demonic85's Avatar
Demonic85
Yeah that makes sense, I never checked the fuse box even though I disconnected the battery. Is there any way that anything could have gone bad by replacing the valve covers? I checked all the injector connections they're good. Of all the cars i've worked on, this one has stumped me everytime I work on it. I'll check the fuse box and some of the wiring too. Thanks guys.
Old Apr 2, 2006 | 10:00 PM
rick lambert's Avatar
rick lambert
Just changing valve cover gaskets ain't gonna make it worse than before, re-check those injector pigails, make sure there on good, there's also alot of vacumn lines in that area-check to make sure there's none disconnected or leaking! And check all electrical connections-AGAIN.
Old Apr 2, 2006 | 10:20 PM
Demonic85's Avatar
Demonic85
Using the A-B pin method of checking codes I came up with these results: Code 12 flashed 3 times, followed by this flash (pause) flash 5 times in a row. It repeated that one 3 times like you guys said it would, followed by the code 12. I dont know how to tell what code this is, could you help? please??
Old Apr 2, 2006 | 10:29 PM
RRT vette's Avatar
RRT vette
After inserting a paperclip or what ever into the ALCL the check engine light will flash once- pause -two flashes bach to back (code 12). This will happen 3 times as you stated. The next set of flashes will be the code. Say if a code 33, there will be 3 flashes back to back - pause - 3 more flashes back to back. And this will repeat 3 times as did the code 12. If there is another code stored it will be a different set of flashes and so forth. When all the codes have appeared it will flash a code 12 again. If there is a code let us know and we can help you troublshoot. As you said it flashed 5 times, make sure there is a pause in between. This could be a code 23 or 32.
Old Apr 2, 2006 | 10:41 PM
Demonic85's Avatar
Demonic85
I understand now, its a code 15. However I highly doubt a low coolant reading from the sensor would cause it to not start. It started raining really bad here, so it'll have to wait until tomorrow. I might get new vacuum tubes tomorrow to see if that fixes it.
Old Apr 2, 2006 | 10:56 PM
AGENT 86's Avatar
AGENT 86
Code 15 is not low coolant.
http://members.shaw.ca/corvette86/Code%2015.pdf
The ecm could be fooled into thinking it's -50 and adding more fuel, thereby flooding the motor. Just a thought
Old Apr 2, 2006 | 10:59 PM
AGENT 86's Avatar
AGENT 86
You did check the connector on the CTS, right
Old Apr 3, 2006 | 12:01 AM
Morley's Avatar
Morley
If the CTS connector is good. disconnect the battery again for a minute and reconnect. Start the car and keep it running as best you can. Shut down when the check eng light comes on or after a minute or 2. check for codes again. If that code 15 is back, replace the coolant temp sensor. They cost about $7 at Advance auto. If the code 15 isn't back and the car still runs like before, start looking for a big vacuum leak.
To Vette will not run
Old Apr 3, 2006 | 11:22 AM
Demonic85's Avatar
Demonic85
I tried it again this morning. I checked all the fuses, they're good. The fuel pump is good and giving plenty of fuel. Rechecked all hoses, lines, etc. I took the gas cap off, put it back on and tried that (my dad's idea). Still wont start and still getting code 15. Checking coolant sensor....
alright, the sensor was unplugged. I plugged it in, code 15 is gone. But it STILL wont start.
Old Apr 3, 2006 | 12:54 PM
RRT vette's Avatar
RRT vette
I am still wondering about timing here. This sounds like when my car was out of time. I know that changing valve cover gaskets doesn't have anything to do with the timing, but. Well also see if you disturbed the TPS sensor on the right side of the Throttle body. Check all the connections on and around the TB. Also check to see if the MAF sensor is connected. These will show codes if there is anything wrong, but it does take a minute or so of run time for them to usually show up.
Old Apr 3, 2006 | 01:22 PM
hz900's Avatar
hz900
Clarify this. Will the engine turn over? If so does it sound like it is trying to fire, just won't "catch", or is the engine just turning over with no signs of firing, ie popping/backfiring. Or does it start but die without the throttle pressed like you said before when you said you could keep it running by pressing the gas?
