Help 2d post left side injectors don't work
Old Apr 7, 2006 | 07:26 PM
Fasterer's Avatar
Fasterer
Default Help 2d post left side injectors don't work
had to do this second post . seems i can not post to my previous post yesterday. is this normal.anyhow. Afterfurther checking with a test light i find i have power on both terminals of all injector connectors both L/s and r/s. With a test light across terminals of any one of the 4 L/s injector connector plugs i get no light while cranking . on r/s i get a light. I swapped out ecm, no change. Am i correct in saying the distributor only has one signal feed to ecm to indicate rotation. Is there any way the dist. could cause this?
Bill
Old Apr 7, 2006 | 08:43 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
What year ??
Did you check the injector fuses ??
Old Apr 7, 2006 | 08:49 PM
RRT vette's Avatar
RRT vette
Originally Posted by AGENT 86
What year ??
Wouldn't blame the distrubitor yet. Check the 2 inj fuses as Agent 86 stated, then use FSM, if you have one, to diagnose further.
To Help 2d post left side injectors don't work
