Water Pump Finally, Broken Sensor ?
Old Apr 8, 2006 | 06:53 PM
ROCKY85's Avatar
ROCKY85
Default Water Pump Finally, Broken Sensor ?
After finally getting the water pump out, noticed burned up wiring connector, it goes to a sensor directly below the small coolant pipe just below the throttle body on the block, it looks simple to replace (hex head top). Which one is it and since the harness connector is shot is a replacment easy to find?
ROCKY85
Old Apr 8, 2006 | 06:56 PM
Dmod81's Avatar
Dmod81
I think that might be the coolant temp sensor. Not sure about a replacement connector.
Old Apr 8, 2006 | 08:07 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's either coolant temp sensor or cold start temp switch.
The plug on the cold start is the same as the fuel injectors. The other is a weatherpack connector..
Old Apr 8, 2006 | 08:34 PM
rick lambert's Avatar
rick lambert
Really sounds like coolant temp sensor.
Old Apr 8, 2006 | 08:44 PM
CFI-EFI's Avatar
CFI-EFI
And neither is in the block. Both are in the intake manifold.
RACE ON!!!
To Water Pump Finally, Broken Sensor ?
