upshift reminder light
Old Aug 18, 2001 | 04:14 PM
88JDO's Avatar
88JDO
Default upshift reminder light
After I had the rear gears changed from 2.59 to 3.54 I have noticed that while cruising in OD that the upshift light comes on at about 2500 rpm. It goes out if I lift my foot off the gas and the rpms drop to around 1900. I don't recall this ever happening with the stock ratio. Can anyone enlighten me as to what is happening?
Old Aug 18, 2001 | 04:30 PM
Bat Man's Avatar
Bat Man
Default Re: upshift reminder light (88JDO)
You've got an Auto?
I have 2.59's and it comes one all the time when I am cruising say in 3rd at 45mph for a while.
It used to say "upshift for best economy" It no longer says "for best economy" wonder why?
Old Aug 18, 2001 | 04:51 PM
88JDO's Avatar
88JDO
Default Re: upshift reminder light (Old Sport)
Yes, it is an automatic. I, too, did see the upshift reminder light when in 3rd gear, but this happens in 4th...upshift to what?
Old Aug 18, 2001 | 04:56 PM
Bat Man's Avatar
Bat Man
Ummm, thats interesting. I don't know, kinda funny too...:lol:
Old Aug 18, 2001 | 05:16 PM
O'Shark's Avatar
O'Shark
Most likely, it is comparing the engine rpm to the vehicle speed for a specified pre-programmed period of time. Your gear changed caused almost a 30% "lower" gear ratio so for all it knows, you are not in your top gear. l'd bet a chip could be burned to include your new parameters.
Randy
Old Aug 18, 2001 | 05:21 PM
A's Avatar
A
Default Re: upshift reminder light (KF9WM's 87 coupe)
That thing is just annoying. I think I'm going to place that bulb somewhere a little more usefull sometime...
Old Aug 24, 2001 | 12:00 AM
TPFKATK's Avatar
TPFKATK
Default Re: upshift reminder light (A)
Howdy!
Did a search, found this thread. My 88 just started with the upshift light. Comes on for no reason at 60 or 70 or 75 mph cruising speed, put a little pressure on the throttle to load the engine, the light goes out. Went to 3.07 from 2.59 about 10,000 ago. Weird. Wondered if it might be a vaccuum issue? Interested in any more feedback.....
To upshift reminder light
