From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Hell, there's SOTP improvements that will actually cost you horsepower. I think the point here is SOTP feeling has no significance whatsoever. It's usually mostly psychological and based on how much money or time was spent on it. For proof, post a poll and ask people if their car 'felt' faster after an oil change.
I replaced some ignition parts on my vette, and it 'felt' slower at the track, I was worried there was something wrong with the car thought I'd head home, until I saw the timeslip, and it was my best run to date.
Putting a percentage on anything is nonsense as far as accesories go.
How could a smog pump steal 14 HP on a motor that make 200 HP and Rob 49 HP from one that makes 700 HP.
Percentages only work with Compression and Cold air calculations.
Uh...the keyword here was supposedly. I don't know how much freakin power the thing draws, and I really don't care. Whatever the draw is, I don't think that it's significant enough to notice a difference with or without. I don't even remember where I heard that, or read it. Who cares? I was just passing along possibly/probably inaccurate second hand info, hence, the insertion of the word supposedly
Actually I said it was a .29 off my best time and 3.5+ mph
Yes you did. I cannot explain where the .07 came from. Maybe I was dropping off to sleep. That is an amazing improvement for just locking a converter. At what point do you hit the switch? Just as you're staging, so it will lock immediately in 2nd gear?
There seems to be a lot if that going around. People read garbage like that and, like a myna bird, repeat it with ZERO knowledge of it's validity and with no concern or sense of responsibility toward spreading falsehoods. "supposedly" Doesn't excuse irresponsible posting. But at least you got to see your name in print.
RACE ON!!!
Believe it or not I locked the converter right off the line in 1st. Yes it did lock in first.
RACE ON!!!
Dyno Sheets solve all disputes. But only when done on the same dyno and properly corrected.
I have experimented with the lock up on my car. I tried locking and unlocking it in every gear possible. On my combination, it did not like it and I slowed down a tenth or two. Some cars do pick up quite a bit from it. It is definately worth experimenting. Do not lock the converter often on a car making over 500hp at the flywheel. The friction material available is only rated at 500 hp. My converter company claims nothing is out there that is rated higher.
You may have activated the TCC right off the line, but that doesn't lock it. The hydraulics of the transmission don't allow the TCC to be engaged in first gear. You could have activated it as soon as you did your burn out. It would have actually locked at the same time.
maybe there was something wrong with my transmission but when I threw the toggle switch it locked up even in first gear. it unlocked anytime my foot was on the brake.
I would leave the line like this:
Foot Brake the transmission on the line, (brake on) turn the switch on, leave on the converter slippage. Within 1.5 seconds in first you could feel the converter locking up. It would pull the motor right down.
I would even lock it driving around town in low gear or any other for that matter and would practically idle up hills. Bog City.
I got an AIR delete awhile back. I didn't and wouldn't pay $170. That's ! Find one used or make your own.
Exactly, and Agent 86 has posted complete blueprints of his that looks almost spot on to what Dragon's Breath makes. A little time and patience, some allum. stock or steel, some tubing for spacers, a pulley and you are there.
I think that post helps me make my point. If the converter will lock in first gear, "turn the switch on, leave on the converter slippage.", there IS no slippage. The engine should have stalled, just as it would have if you'd have dumped the clutch on a stick shift. It is my understanding that the TCC solenoid activates a hydraulic circuit that engages the TCC, and that the hydraulic circuit is blocked by other means in first gear. I admit I don't know a ton about automatics, but it seems to me that either you were slipping the heck out of the converter clutch or the TCC doesn't engage in first gear, as I thought. Where is Pete K. when you need him?
Different years, makes, and models used different wiring arrangements to lock up the converter. Probably 20 or more viariations I have not seen any that locked up the converter in 1st or second gear. I "think" that one or 2 versions would allow for a possible 2nd gear lock up. I will look into it. I "think" factory first gear lock up would be totally out of the question. I will research both possibilities. I have tried to lock up 1st with a jumper harness for track testing and it did make the car lug and stall out. Most guys I have met (that claim to gain from locking t/c)seem to lock the converter at the 1000 ft mark or so. Usually around 100 mph assuming a 115-120 mph trap speed. The guys on TGO (in the diy prom section) have experimented a bit with this. I do plan to try it again on my car to see if it responds.
CFI_EFI is correct in how it applies. The ecm commands it based on the programming in the chip. Then the hydraulic circuit in the valve body trips a switch to finish the job.
