Two to three horsepower. Maybe as much a 5 HP over 6000 rpm. Will you feel it? That depends on how much trouble the project gives you and how much you end up spending. The harder the job and the more costly, the greater the S.O.T.P. rewards. Beyond "feel", there will be no measurable performance gain.
Since when will a car give you a great S.O.T.P. feel and not be measured on a drag strip. I have done minor mods you couldn't feel and they translated to hundreds to tenths off my times. The biggest SOTP was locking the torque converter right off launch which netted me .3 and 4 mph. That was awesome but the repeated abuse cracked the output shaft of the transmission. SO try it once get your timeslip and retire it before it breaks.
Does that mean the same thing as hundreds OF tenths? There are 10 tenths in a second. One hundred tenths is 10 seconds. If you have cut hundreds of tenths off your 1/4 mile, you must get to the other end before you leave the line. S.O.T.P. improvements don't always translate into an increase in measurable performance. An example would be how your car always runs better just after you wash it. Thank you for helping me make my point.
Hundreds or even as much as a tenth or more. Couldn't feel it either way.
The ONLY ONES I did feel were:
Switching from 3.07 to 3.73 netted about an average of .3 tenths and 2.5 mph.
Locking the Converter was about .29 off my best and 3.5+ mph.
one that didn't feel like much of anything:
All I got was a Quick bump in the back From a shift kit. .07 seconds and about .8 mph, definately not seat of the pants.
Nothing at all:
MSD 6A ???????? no improvement I noticed
Fluidamper ???? seemed to go .01-.02 slower could have been weather.
big thumbs up to BFG 315/35/17 drag radials, consistent, consistent, consistent.
one day out I went 12.651 (170 water temp), 12.673 (180 water temp), 12.659 (165 water temp), 12.674 (170 water temp), and 12.653(160 water temp) The track warmed about 15 degrees over the day. with all the trees in the .05's or better with one .003. Where was corvette day then??????????????????
The one that surprises me is the .07 from locking the converter. I'll have to try that.
But again, you help me prove my point in that what you feel (S.O.T.P.) isn't always verified on the time slip. In your cases, you felt nothing but got a little. It goes the other way, too. Usually the S.O.T.P. improvement is directly proportional to the expense or effort involved in the modification.
i just purchased that air pump replacement pulley from mid america. I must say it looks nice and is a nice solid peice of metal not worth $170. But i busted my alt to air pump bracket and this replaced that, and i eliminated ALL of my emmissions crap.
I just removed mine - then took out the EGR tubes that run down the sides of the intakes - filled the holes with weld - and ussed some 3/4 inch by 1/4 inch bar stock heated it up a few times - used some spacers and washers and fabbed up a replacement pulley. Total cost - about 6 bucks - and a few hours of my time. I took em out because they were in the way. I didn't feel any performance changes!
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
FWIT...
I installed a Breathless Performance delete on my "88 -Polished.
Really cleaned up the engine bay.
However (as I posted last Fall) I was experiencing some huge crankcase pressure at high RPM under Nitrous/drag race conditions.
Anyway, I installed (had it done) a crankcase evac system that uses a belt driven airpump using the OEM bracket for the original airpump which caused me to remove the nice Elim Bracket/pulley from Breathless and retro the old one.
So now I have a polished elim kit that I don't use. Interested?
Matt,
after eliminating mine - I seem to have increased oil pressures - what used tgo be 42 lbs at idle and 60 at 2200 rpm now is 60 lbs at idle and 72 - 75 lbs at 2200 rpm. any correlation?
Carl Johansson
Originally Posted by Matt383
FWIT...
Originally Posted by Carl Johansson
Matt,
Carl Johansson
Wow! That's a lot of PSI at 2200 RPM.
My motor is a bit different than yours I am guessing, so the variables are endless to draw a direct comparrison/conclusion based soley on the air pump. (see my sig)
But you may have something there.
My pressure went real high at 6000+ rpm, more on the juice.
My compression is 12:1 and I am close to 390 C.I.D. FWIT.
Now with the crankcase evac I watch my PSI actually drop as I go over 3500 rpm as it is belt driven.
FWIT...
Matt383
Matt are you saying by deleting the AIR pump it increased your oil pressure?
I wish I could tell you.
I deleted it on the last engine build, so I do not have "before and After" data.
In other words, I had it on the old motor and deleted it on the new motor. The new motor never had the air pump.
Sorry.
Sorry.
Matt383
NoProb man, just was about to remove all that junk and was just wondering what in the AIR system would create an OP increase. Course I too am hoping to have a new motor built soon as well...
I removed the AIR diverter module from mine and it cleaned up the passenger's side engine bay pretty well. I just wrapped up the solonoid connectors with black duct tape and set them aside tucked somewhere near the A/C compressor or valve cover. Looks pretty neat now.
That smog pump now just blows air in my engine compartment and its not really that much air to be useful as a supercharger.
RACE ON!!!
Actually I said it was a .29 off my best time and 3.5+ mph
