Source for aux fan sensor?
Old Apr 17, 2006 | 06:27 AM
jerkyboy's Avatar
jerkyboy
Default Source for aux fan sensor?
Looked thru ecklers and MAD for the sensor on the drivers side head that runs the aux fan. I need the sensor and both sides of the connector as my headers melted the whole thing. Thanks
Old Apr 17, 2006 | 08:09 AM
rodj's Avatar
rodj
thought I had seen it in there also.
Here's one that is lower start temp ,
http://cgi.ebay.com/ebaymotors/NEW-T...tegoryZ46096QQ
itemZ8056237810QQrdZ1QQsspagenameZWDVW
The plug is available from Ecklers as a replacement pigtale
Old Apr 17, 2006 | 08:25 AM
mseven's Avatar
mseven
Why wouldn't you want a regular GM one? The temps for the fans are programmed in your chip aren't they?
Old Apr 17, 2006 | 08:32 AM
rodj's Avatar
rodj
Aux fan runs direct off sensor on early models, no ECM involvement
Old Apr 17, 2006 | 08:33 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check your local parts supplier. Pigtail for knock sensor or aux fan switch are the same. Napa has a variety of temp switches with different on/off temps. I crossed one of their numbers to get one local. I got a Niehoff TS25691 temp switch, on at 200*
Old Apr 17, 2006 | 08:47 AM
jerkyboy's Avatar
jerkyboy
Thanks guys. It's one wire right? That's all I've found left after the meltdown
Old Apr 17, 2006 | 08:55 AM
AGENT 86's Avatar
AGENT 86
rick lambert's Avatar
rick lambert
In stock form it's one wire-my aftermarket lower temp switch came with two, which helped me wire both main fan and aux. fan in tandem-now both my main and aux. fans come on at the same time-which is what I intended and am very happy with.
To Source for aux fan sensor?
