Without Pulling Crank Pulley
Old Apr 17, 2006 | 05:57 PM
adamc's Avatar
adamc
Default Without Pulling Crank Pulley
completed: changed optispark and cap and rotor without pulling the crank pulley. it can be done '94 LT1.
Old Apr 17, 2006 | 05:59 PM
STL94LT1's Avatar
STL94LT1
You must be a magician.
FYI: It only takes about 5 minutes to remove the crank pulley.
Old Apr 17, 2006 | 07:35 PM
rickneworleansla's Avatar
rickneworleansla
How?
Old Apr 17, 2006 | 08:42 PM
adamc's Avatar
adamc
Default so dont believe...
so dont believe those posters that say the pulley has to come off to change the opti. It does not. It doesn't take a magician. Since it takes more than 5 min to get the crank pulley off...you might find a magician for that job. So I have seen posts on this board that recommend anything from beating the crank pulley off with a 2x4 to unbolting the engine mounts and raising the motor to access the pulley. Forget it. Leave the pulley alone. It is probably siezed to the crank anyway and will never come off. The opti can be changed without removing the crank pulley and I know this because it has just been done on my '94.
Old Apr 17, 2006 | 08:45 PM
dock351's Avatar
dock351
St. Jude Donor '06
Sounds good. . . r u going to describe how you did it?
Old Apr 17, 2006 | 09:40 PM
96GS#007's Avatar
96GS#007
So tell us again how you managed to get the opti past the balancer....
Old Apr 18, 2006 | 01:32 AM
500hp's Avatar
500hp
You must be referring to the crank HUB. The stock pulley/damper is held on with 3 short bolts and is only about 1/4 inch away from the Optispark. If you have an ATI damper, then there IS enough room to remove the Opti without touching the 'crank pulley'.
Old Apr 18, 2006 | 02:15 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Otherwise, I have to call on this one.
Old Apr 18, 2006 | 08:17 AM
69mako's Avatar
69mako
The crank hub can stay on The balancer has to come off
Yes this I know...for I have changed an opti and live to tell the tail to all who will listen
It's not that bad a job, 5.25 hours in my garage with a bunch of buddies standing around drinking my beer as I do the work
I would have never made it with out their support
Old Apr 18, 2006 | 08:35 AM
aboatguy's Avatar
aboatguy
I can't remove the opti on my '95 w/o pulling the balancer!
Old Apr 18, 2006 | 08:41 AM
pcolt94's Avatar
pcolt94
Always wondered about that but never tried to get the opti off with balancer on. I know the shops wouldn’t take it off if they did not have to. Did an opti in January and March. The first time it took me hours to get the balancer off. Quit the first day from flat out failure. Came back the second day, saw it slightly moved and with new motivation succeeded. Sanded the mating surfaces at the hub and slightly lubed. The second time it flat out fell off when I removed the last bolt. Guess next time I'll check it closer but I think it's got to come off also.
Old Apr 18, 2006 | 09:53 AM
rickneworleansla
Default opti
I'm interested in doing this on my 95. If there is an easier way I'm all . I'm considering changing my opti for the new msd model.
I already have the new wires and plugs what should I look out for when changing them this weekend.
Old Apr 18, 2006 | 10:31 AM
pcolt94's Avatar
pcolt94
I did my wires when I did the opti the first time. Good luck in doing the left side, would like to know if you can. Removing the water pump and tensioneer gives you all the room you need. Perhaps you can just remove the tensioneer and see if that works out. Charge on!
To Without Pulling Crank Pulley
