Ecm
Cheri
Do yourself a big favour and buy the GM Factory Service Manual, www.helminc.com, NOW. Don't wait another second.
As for the ECM, I would be STUNNED if it is causing it to NOT start. To me, it sounds like there is a VATS failure.
VATS is anchored by this puck in the key. If you have another key, try that.
If the VATS does not get a good code, it will keep the engine from starting. However, the VATS handshaking is done by the CCM to the ECM. If the CCM is not satisfied with the key, it will send a no-start message to the ECM... and that is what it will do - NOT START!
ECM = Engine Control Module - it's the computer that keeps the car running. The ECM is under the hood, left side, near the windshield, above the battery.
The CCM is the Central (sometimes called Chassis) Control Module. It is inside the dash, under the radio, and a bit behind.
I would start with VATS and work back from there.
Any codes from the computer(s)?
There are two ways to read the codes... one is via the CCM (the codes display on the speedo) the other is via flashing the SES light on the DIC.
If the bulb is blown on the DIC, that would be a false lack of code! When the key comes on, make sure the SES light selftests. If not, chase that first (dead bulb would be my first guess).
A C12 means that things are working and reporting ok...
There are countless other reasons why your engine will not turn over or not start and run. Detailed information needed for better feedback. Would like to help more.
