Question from new member
Not knowing the history of the car, I am thinking of getting all the fluids changed. This is not cheap. I did examine the fluids and they seem like they are in good shape. Specially the trans fluid. Any opinions on this would be appreciated.
The noise I am hearing from the engine only occurs when the engine heats up. It is a higher pitched tapping sound that seems to be coming from the front of the motor.
I am thinking water pump. However, according the gage the car is not running hot. In fact the car is performing to my knowledge very well. Good smooth power, idles well etc. Because the sound is a tapping sound I am concerned it is coming from the valves. This Friday I have an appointment with a local garage to have the car checked over. My wife bought the car from a dealer with a 3000 mile warranty. Any tips from you experts on what I should look at or ask the mechanic to check would be appreciated.
FYI the car has had four owners, two in the last 5 years. My wife bought it from a dealership in Buffalo New York (it was a trade) and had it shipped home to Ottawa, Canada. We joined the Capital City Corvette Club and are looking forward some sunny hot cruising weather and good times.
Just some advice....try to learn as much as you can about your car and the problem you have before you go to a garage. They will try to take advantage of you, it will be your knowlege alone will prevent you having to spend lots of money for lies.
With only 3000 miles on the warranty, I'd make sure she gets thoroughly checked out - preferably by a qualified shop familiar w/ Vettes.
Other than that, ENJOY!
What a wife.
It COULD be your alternator going out. I've heard them make a mechanical, clacking sound before they tank.
Enjoy your Vette and congrats. We're glad you found us here.
I might be wrong but I believe my car has the L98. Also to answer your other post I washed the engine compartment last night at the jet spray. I did keep my fingers crossed when I started it and drove home.
Luckily I had no problems.
I agree, the tapping could be anything- hard to diagnose, but you could always time the tap to determine its frequency, then you could deduce from where it might be coming based on RPM and knowledge of moving things connected to the crankshaft (i.e., pulley diameter ratios for accessories, cam driven items that are operating at half the crank rpm, etc.)
Welcome to the forum, and congratulations on your purchase! I wish you many trouble-free miles!!
Suggestion: since you joined the Corvette club, call up the prez, ask him who's the most mechanically experienced with the L98 in your car. Call the person if the prez will give you his/her number and ask that person to come over, or let you drive over to hear the noise/sound. All BEFORE you go to this local mechanic, who I'm sure will be experienced with Corvettes (if not, ask the club for recommendations of others).
Yes, to changing the fluids, esp. the auto trans (I'm assuming that's what you have, if not, change the man trans fluid, too). Yes, it's expensive, but think about it: this is a '91, 15 years old. Chances are VERY good that not one of the four prior owners had some or all of the fluids changed. Why? The car had what? 10K miles with the first owner, 20K with the second, etc., etc., so why would they think of changing it "at so low a mileage"?
Tell us with a follow up what happens to the car as far as outcomes and do post some pics!!! We're picture hounds!
It was not on all the way and the front drivers side is hard to get to. It was an illusive problem.The opti, water pump alternator is probably not going to give you tap sound. The fan belt, if I bad shape could be another possibility (small). Since only you can hear it, listening very closely and a good visual inspection is something you can do. Keep an open mind and your options open. Good luck and welcome.
RACE ON!!!
